tangocharlie123 Posted May 3, 2010 Posted May 3, 2010 Does any body know where to get the bowden cables that Jabiru use or do they import them themselves Cheers
HEON Posted May 3, 2010 Posted May 3, 2010 Not a Jab flyer so not sure. Are these cables the same as what I know as morse cables; a heavy duty push/pull cable? If so, they can be custom made by "better" marine shops as they are used in steering etc in marine field. As you seem to be going 19- rego they could be used if you think suitable.(I think) Was a mob in the 'Valley that did them...think they could have been Morse cable dealers
robinsm Posted May 4, 2010 Posted May 4, 2010 For lightweight ones, go to your local bicycle shop Cheers Maynard
facthunter Posted May 4, 2010 Posted May 4, 2010 Control cables. Bowden cables were made by a firm of the same name in England in the teens last century. They made levers and fittings for motorcycles and were even fitted as original equipment to the Indian motorcycles in america, (they called them Indian Motocycles then) of the period. The Bowden cable PULLS only. Stranded inner and flexible outter. Nev
jetjr Posted May 4, 2010 Posted May 4, 2010 Tuthills cables in Melb I think?? They get funny when you say its for Jabiru and make you buy it through them Apparantly they mke teflon lined ones which are much better too
facthunter Posted May 4, 2010 Posted May 4, 2010 Teflon lined. Teflon would be a good thing. Do the originals have that feature? nev
jetjr Posted May 4, 2010 Posted May 4, 2010 Apparantly not It has been raised in regards to autopilot, the increased resistance can be a problem with std cables. In normal flight normal cables seem OK
cherk Posted May 4, 2010 Posted May 4, 2010 G'day TC123, Try " Flexible Drive Agencies P/L ".....in all states...( Flexible Drive Agencies Pty. Ltd )
tangocharlie123 Posted May 4, 2010 Author Posted May 4, 2010 Thank You Thanks Guy's I will contact Tuthills in melb. I aready use the flexible drive ones but want a comparison of weight flex and strenghth lets see how I go. Happy Building and flying
Guest Baphomet Posted May 4, 2010 Posted May 4, 2010 I see you are in Brisbane. There is a shop in Sandgate that sells them made to order for the marine market. I'll try and find the contact details. Baph
Brett Posted August 22, 2011 Posted August 22, 2011 Has anybody had any luck contacting Tuthill in Vic lately???? I have been trying on and off but only ever seem to get an answering machine? Flexible drive agencies can make and replace this bowden cable I'm after but not in the original green type that the other 3 are made of.. they can make them in black,,,, just thought it would be nice to keep everything the same .....
