TiGmsm Posted January 29, 2010 Posted January 29, 2010 Hello, I just installed the Evektor SportStar from http://files.fsnordic.net/?download=2157 and I'm having a problem with the cockpit dome being completely black and blocking all visibility. If I open it, via the open door command, I can see around it just fine. The expected clear dome is just completely black. Any suggestions on how to fix this problem? System: Windows 7 64-bit, 8GB, ATI Radeon HD 5850 Thanks for your help. -Bob
Owi Posted March 21, 2010 Posted March 21, 2010 Hi Bob, I haven't got that particular add-on, but it does sound like a common problem. I see it does say "FSX compatible", but no mention of DX10 support. Do you fly with DX10 preview enabled? If so, I reckon you need to turn that off. Also, I see there's an update to 1.1. Have you installed that? Good luck, EDIT/Addendum : I just tried this plane on my FSX. I get the same problem as you but I noticed you can see out the canopy where the stickers are. Maybe, if one had patience, it could be fixed by editing a file? Pity - it looks like a good piece of work.
