Old Koreelah Posted December 29, 2009 Posted December 29, 2009 Can anyone suggest what revs a healthy Jab 2.2 will reach if tethered and ground run with throttle wide open? This might tell me if I have everything set up correctly. Regards, Lyle
biggles Posted December 30, 2009 Posted December 30, 2009 I think you will find that it depends very much on the diameter and pitch of the prop . With a Jabiru prop you should get around 2800 RPM with a 60x42 and around 2700 RPM with a 60x44 , for other props I suggest you ring Jabiru . Regards Bob
slartibartfast Posted December 30, 2009 Posted December 30, 2009 I believe the aim should be 2800 - 3000.
BigPete Posted December 30, 2009 Posted December 30, 2009 My old bus (J160c) climbs out at 2900 RPM at 70 - 75 knots. (60 x 42) regards
brilin_air Posted December 30, 2009 Posted December 30, 2009 Our 160 does 600 ftpm 90 knots at 2900. Ground running 2800, with a 60x44 prop. -Linda
Old Koreelah Posted December 30, 2009 Author Posted December 30, 2009 Thanks for the replies, people. I forgot to specify my prop, which is 60 X 42. Regards, Lyle
facthunter Posted December 31, 2009 Posted December 31, 2009 Power Check. Considering part of your original question, it also has ongoing relevence. The RPM figure, (if you determine what it is, and you are doing that), WILL give a good indication of delivered power.(Fixed pitch props ONLY) This is something that is not mentioned very much with our aircraft, but you should have in your mind when you open the throttle, an RPM figure which would be acceptable. Obviously anything below that would mean rejecting the take-off. You might find that the carb. heat is on or something else is wrong. Dont take a known problem up into the air with you. There are enough Unknown problems there already. Nev
Guest Qwerty Posted December 31, 2009 Posted December 31, 2009 Dont take a known problem up into the air with you. There are enough Unknown problems there already. Nev Brilliant, thanks for that one.
pudestcon Posted January 1, 2010 Posted January 1, 2010 Well said Nev, I'm going to use your 'Known, unknown' quote quite a lot - especially to myself!! ;) Pud
facthunter Posted January 1, 2010 Posted January 1, 2010 Saying. Thanks fella's I first thought of it as a good philosophy in 1966 when I was doing a check ride. I informed the Captain that there was a clip missing from one of the rear doors. He said "well here's a chance for you to show initiative. What would YOU do?" I responded with what I thought was an appropriate response. Ie the quote above. and a LAME was brought out and the missing part fabricated. We were delayed some hours as it was the middle of the night. I only found out many years later when I got access to my files that he had written me up as "failing to show initiative". SO I must warn you that it doesn't work. (But I still use it)...Nev
Yenn Posted January 1, 2010 Posted January 1, 2010 If you get a chance try writing up his file as failing to show responsibility.
facthunter Posted January 1, 2010 Posted January 1, 2010 Fix. In the absence of the Wrath of God, I tell myself that "Time wounds all Heels". Nev
Guest check-in Posted January 2, 2010 Posted January 2, 2010 Back to the prop question. I recently bought a beautiful ground adjustable composite prop from Rob Patroney. He told me to set the initial blade angle at 14 degrees and take it to full throttle in the cruise. He said it would be optimum if it made 3300 rpm. Which is exactly what it achieved first go. Now goes like a cut cat whereas with the old wooden prop it was a bit slow even though it would make the 3300 rpm. I think the old prop had too much pitch and not enough diameter (it was only 54 inch dia whereas the new one is 60 inches). Although I have never tried tethering it and flogging the engine in a static condition, the Sonex book says 2750 rpm static is the target. On takeoff I look for about 3000 as it accelerates through 50 knots but by then it's all happening a bit fast, so it's a very quick look. Aircraft is Sonex with Jab 2200.
