Can anyone supply some good, easily remembered pilot checklists (preflight, engine failure, nav, etc)
I'm making up some checklist cards and want to ensure I haven't missed anything.
Regards,
Lyle
Guest check-in
Do you mean written checklists, or memonics? If you do go down the written checklist path, you need to sit in the cockpit and write it in some logical 'scan' sequence - Left to Right or Top to Bottom etc. Which is fine up until you start to taxy, but thereafter until stopped at the end of the flight, a written checklist in a single-pilot aeroplane is not such a great idea. You need to look where you are going, not have your head down in the cockpit.
When I learned to fly in basic single-engine machines we never heard of written checklists. We were taught to scan in some logical sequence e.g. brakes ON, fuel ON, radios OFF, battery ON, beacon ON, start engine - immediately check oil, fuel, generators and suction, radios on etc.
Then for take-off we used a simple memonic which covered everything - even stuff not fitted to those simple aeroplanes but stuff we would have to contend with in the more complex machines later. One was TMPFISCH which was:
Trims - set
Throttle friction - firm
Mixtures - rich
Pitch (prop) - fine
Fuel - on, quantity, pumps (as appropriate to type)
Flaps - set for T/O
Instruments - suction, gyros etc
Switches (magnetos) - checked & on
Cowls - open (as appropriate to type)
Carb heat - checked & off
Controls - full & free movement
Hydraulic pressures (as appropriate)
Hatches (canopy) - locked
To cover landing it was BUMPFH being:
Brakes - off
Undercarriage (landing gear these days) - down 3 greens
Mixtures - rich
Props - fine
Fuel - on, pumps (as appropriate)
For most RA aeroplanes you could cut out a lot of the above, but still have some sort of memonic.
No doubt others will have other memonics and yet others will espouse the need for a written checklist for everything. If you are hiring a school's aeroplane you will be obliged to go with what they do. If you are flying your own, why not develop your own method? The mere act of developing it will make it easier to remember. Keep it simple and logical so that you will always use it. If you get distracted or interrupted (e.g. on the radio half way through your pre-takeoff checks), just start again.
Thanks for the prompt reply.
The purpose of the cards is, as you suggest, to assist with memorizing the checklists. Although its tempting to make my own lists, I want to stay relevant to other types, which is why I'm looking for a standard (I'm surprised I can't find checklists on the net)
If anyone is interested, I'll add what I have so far. (I've adapted a couple of gems from gliding days, mostly because they were hammered so well into my memory!) Some need work because they are not easily memorized like CHAOTIC, or TBUMFISH
PILOT
I - illness
M - medication
S - stress/pressures (get-there-itis?)
A - alcohol/drugs
F - fatigue
E - eating
AIRCRAFT
Aircraft- exterior, pitot cover, vents clear
Ballast- load distribution
Controls - full & free, 'panel rises to meet control'
Dolly- tiedowns, pennants, etc
Engine-oil, bolts tight,
Fuel- sufficient, caps, connections, taps on
drain samples, smell, swirl, contaminants
ENGINE STARTING
Brakes on, throttle, choke set
Battery on, Main switch,
Fuel on, pressure up,
Ignitions
"STARTING UP, STAND CLEAR OF THE PROP" Crank
Oil pressure
Oil pressure, temp
Ignition check- left, right, both off momentarily, Carb heat.
Brakes off, Airbrake closed
Line up runway, compass check
PRE TAKEOFF
BRS- remove safety pin
Controls
Harness
Airbrakes
Outside
Trim
Instruments - temps, oil, alt, Compass, Canopy
CLIMBOUT
Full power, 60kt
@ 300ft- fuel pump OFF
@ 1000ft leave circuit
Power, Attitude, Trim
LEVEL OFF
Attitude, Power, Trim
Radios - Correct frequencies
Navigate
ENGINE OUT AFTER TAKEOFF
Airspeed - 50kt
Best place to land -in 60° arcXXXXX
Fuel - OFF
Ignition - OFF
Airbrake
Master Switch - OFFX
Battery- isolated
ENGINE OUT DURING CRUISE
Airspeed - 50kt
Carb Heat ON
Fuel- ON (SWITCH TANKS if applicable)
Fuel Pump- ON
Ignition Switch -BOTH (crank if stopped).
PRE LANDING
Traffic checks
Brakes
Undercart
Mixture
Fuel selector & quantity checked
Instruments - ASI, temps, pressures
Switches - Lights, fuel pump on
Harness & hatches
DOWNWIND LEG
Radio call on “Turning Base”
AFTER LANDING
Fuel pump OFF
Carby heat OFF
Lights & strobes OFF
BRS safety pin installed
Guest check-in
It's highly unlikely that you will find a 'standard' checklist due to the variety of different types, engines etc. Aircraft manufacturers usually publish checklists within either the Aircraft Flight Manual (AFM) or Pilot Operating Handbook (POH). However - to avoid possible litigation - these tend to cover every item you do and so often take the form of detailed instructions. Not a very user-friendly format once you are out there. For example the POH 'checklist' will likely say:
Seats - adjust until your eyes are aligned with (whatever reference point is applicable)
Rudder pedals - adjust so that you have full travel with legs extended
Seatbelts - fit 3 point harness
etc etc (so far these are 'airmanship' items so I would not consider putting them on my own checklist because it would end up too long, and anyway, if you can't remember this stuff, you will be in real trouble remembering what happens when you pull the stick back).
A typical AFM or POH checklist would probably even give a detailed engine start procedure such as:
Primer - operate 4 strokes if engine is cold, two if hot, then lock
Ignition - select 'both'
Starter - engage, release when engine is running
etc etc etc - stuff that you should be able to accomplish without referring to a checklist.
Summing up, a checklist should be restricted to essential SYSTEMS items only. Not to be confused with AIRMANSHIP items. Additionally, certain emergencies require MEMORY items. Engine fire on start-up for example, where you won't have time to be rummaging for a checklist.
