Guest The Bushman Posted September 24, 2009 Posted September 24, 2009 I listed a report on this site as to Hard Starting Jabs well I now have the answer and after now doing 2 engines and both starting on the 3rd Revetation and both on a cold frosty morning I have still some more to do then will list the procedure to follow Remember Starter ok Battery good then my 5min Mod and away she goes each and every time The Bushman
Guest Qwerty Posted September 25, 2009 Posted September 25, 2009 Revetation?? = invitation from a reverend ? Is Vet a verb? Could be, re-vet-ation? As in the act of re-veting?
facthunter Posted September 25, 2009 Posted September 25, 2009 Picky. The only good thing I have seen on a church billboard. "Mud thrown is ground lost". IF you are not carefull, you may not get the answer.. Nev..
cherk Posted September 26, 2009 Posted September 26, 2009 Remove both "o" rings from the starter motor....(steel thru-bolts are too resistive !) and add earth lead to the rear (brush end) of the starter.........been there etc. etc.
facthunter Posted September 27, 2009 Posted September 27, 2009 Fix. I saw the above recommendation on the Jabiru site a fair while ago. I don't have a Jabiru, but I work with starter motors, and this seems like the most likely point to start with. (pun not intended). With starter motors, if you crank them for a short while and then feel for hot terminals, end caps etc the heat will tell you where the problem is most times .Nev. ...
Guest The Bushman Posted September 29, 2009 Posted September 29, 2009 hard Starting Jab nice try but no where near it ?? and after the comments about the incorrect spelling, we are not all perfect Now done several aircraft with all owners very pleased with result the answer now stays with me The Bushman thumb_downthumb_down:censored:
Guest ozzie Posted September 29, 2009 Posted September 29, 2009 i'll get the rope. someone find a tree!
Guest Qwerty Posted September 30, 2009 Posted September 30, 2009 nice try but no where near it ??and after the comments about the incorrect spelling, we are not all perfect Now done several aircraft with all owners very pleased with result the answer now stays with me The Bushman thumb_downthumb_down:censored: Bushman If my comment offended, I appologise unreservedly. My aim was not to upset you. I do not claim to be perfect. Obvoiusly my sense of humor is not perfect. Qwerty
Jabiru Phil Posted October 1, 2009 Posted October 1, 2009 Come on Bushman lets onto the secret!!!!! Worth a carton of Fosters for the correct answer. Phil.
theoy Posted October 1, 2009 Posted October 1, 2009 Bushman has it any thing to do with an extra ignition ? below one of your posting from April 09 Cheers Theo Phil thanks for the carton LOL "Cold Start Jabby " " Hi Why not fit Auto ignition from four cylinder car Electronic have been using one for years three switches on full choke one or two turns and away, and if the battery is Flat hand cranking can be done so beware my Jabby Bites ?? once started turn off Third Ignition,:Flush::Flush: last Battery I replaces was stuffed could just start engine but still did The other morning at Bourke there was 1/2 inch of ice on the wings after overnight outside 3 clicks two turns and away she goes best system I have every used The Bushman "
Guest The Bushman Posted October 1, 2009 Posted October 1, 2009 jab 2200 hard starting :faint:no standard ignition as fitted the third ign was to hand start, the mod is to allow starting as normal second or third Revolution of the prop (Checked the Dictionary) The bushman
ianboag Posted October 3, 2009 Posted October 3, 2009 So how does a Kiwi find out the answer? It's colder here ......
theoy Posted October 4, 2009 Posted October 4, 2009 Technical - Jabiru Light Sport & Experimental Aircraft are we getting warm?http://www.jabirupacific.com/tech.htm#ColdWeatherStarting
jetboy Posted October 4, 2009 Posted October 4, 2009 "Hard starting jab As reported in a earlier Forum My New members jab was very hard to start Well now starting on the second or third swing on a cold Morning Found that in the enrichment disk in the carby needed to be drilled out to 1/16 and turn the disk around to the 8 oclock position (Dot on the Shaft) and this engine is only 10 hrs old from Factory also will futher test and may need to increase jet size in bowl for choke side off fuel supply now 80 85 available as standard James" The above was posted last month (linked at the bottom of this thread) I dont know if thats what is been kept secret however its not really applicable unless the status of the drilling (or not) of the idle air hole and the idle jet size are known for a particular engine. These items changed a lot with the various issues and revisions of the carb tuning kit. As I've not had cold starting problems but keep a can of SYB handy as a threat - just reading the label cheers me up. Ralph Ralph
theoy Posted October 27, 2009 Posted October 27, 2009 where's the info on hard starting Mr bushman? gone walk about? LOL
Guest Maj Millard Posted October 27, 2009 Posted October 27, 2009 Well you've upset him now, touchy,touchy. It's also known as the golden rule. When you've got the gold, you make the rules !!....................................................................
flyer49 Posted October 29, 2011 Posted October 29, 2011 Well you've upset him now, touchy,touchy. It's also known as the golden rule. When you've got the gold, you make the rules !!.................................................................... Hi all, it seems to me that a lot of people have spent a whole lotta money on shiny new aircraft that dont like to start on cold mornings. Why not refer the problem to the people who should be addressing the issue? !!!... Jabiru Aircraft Company!!, Happy cranking.
Guest cficare Posted October 29, 2011 Posted October 29, 2011 closing the gaps on the plugs works in tassie...
bushpilot Posted October 30, 2011 Posted October 30, 2011 We tried all the fixes mentioned above on one of our J230s and it still refused to fire on cold mornings here in Bathurst.. Then 'the factory' suggested trying NGK Iridium plugs = now starts every time and pulls more revs. - and the plugs last 'forever'. (At this stage only approved for use in the 3300 motor - something to do with certification).
