fix the balance problem with Evektor SportStar
Guest Brett Campany
Hey guys, if you've got the Evektor EV97 for FSX and you've found that it keeps going to the left, well I've been working on the fix.
Follow these steps-
Open:
Microsoft Games/Microsoft Flight Simulator X/simobjects/airplanes/ev97
Look for the aircraft.CFG file and double click it. When it asks what program to open it with, use "Notepad".
Now before you make any modifications, make a copy of the aircraft.CFG file and put it in another folder incase this doesn't work for you. I'm 99.9% sure it will work though.
OK, open the "aircraft.CFG" file inside the EV97 folder and over write the contents with the text below. Once you've done that, close the file, click "yes" to save it and go flying. Any issues, place them here.
COPY EVERYTHING BELOW THIS LINE.
// EV-97 Eurostar Aircraft configuration file
// by Oskari Syynimaa
[Fltsim.0]
title=EV-97R Eurostar OH-U507
sim=EV97_Eurostar_Rotax_912UL
model=
panel=
sound=
texture=oh_u507
kb_checklists=
kb_reference=
atc_id=OH-U507
atc_parking_types=RAMP
ui_manufacturer=Evektor-Aerotechnik
ui_type=EV-97R Eurostar
ui_variation=OH-U507
atc_heavy=0
atc_airline=
atc_flight_number=
description=OH-U507, the real aircraft that this model is built upon. Flying in Finland. Rotax 912UL 80HP version.
[Fltsim.1]
title=EV-97R Eurostar SE-VAR
model=1
panel=1
sound=
texture=se_var
kb_checklists=
kb_reference=
atc_id=SE-VAR
ui_variation=SE-VAR
atc_heavy=0
atc_airline=
atc_flight_number=
description=SE-VAR is one of Höganäs Flygklubbs´ two Eurostars. Rotax 912UL 80HP version.
[Fltsim.2]
title=EV-97R Eurostar OH-U402
model=
panel=
sound=
texture=oh_u402
kb_checklists=
kb_reference=
atc_id=OH-U402
ui_variation=OH-U402
atc_heavy=0
atc_airline=
atc_flight_number=
description=OH-U402. Flying in Finland. Rotax 912UL 80HP version.
[General]
atc_type=Ultralight
atc_model=Eurostar
performance=Wing Span: 8,10 m\nLenght: 5,98 m\nEmpty Weight: 269 kg\nMaximum Gross Weight: 450 kg\nFuel Capacity: 65 l\nEngine: Rotax 912 UL\nSeating: 2\nCruising Speed: 180 km/h\nService Ceiling: 5000 m\nRange: 750 km
Category=airplane
[CameraDefinition.0]
Title="Left Wing"
Guid={3A09FD6C-D906-4d8f-A5CD-FA4F5E0C12ED}
Description=View from the left wing tip
Origin=Center
SnapPbhAdjust=Swivel
SnapPbhReturn=FALSE
PanPbhAdjust=Swivel
PanPbhReturn=FALSE
Track=None
ShowAxis=FALSE
AllowZoom=TRUE
InitialZoom=1.0
ShowWeather=Yes
InitialXyz=-7.5,0.75,0
InitialPbh=5,0,90
XyzAdjust=TRUE
Category=Aircraft
ClipMode=Minimum
[Weight_and_balance]
max_gross_weight=992.080
empty_weight=593.040
reference_datum_position=0.928,0.000,0.430
empty_weight_CG_position=-0.735,0.000,1.400
max_number_of_stations=3
station_load.0=95.000000,-1.640000,-0.150000,0.700000,Pilot
station_load.1=95.000000,-1.640000,0.150000,0.700000,Passenger
station_load.2=0.000000,-3.870000,0.000000,0.700000,Baggage
;Moments of Inertia
empty_weight_pitch_MOI=700.000
empty_weight_roll_MOI=200.000
empty_weight_yaw_MOI=900.000
empty_weight_coupled_MOI=0.000
CG_forward_limit=1.080
CG_aft_limit=1.390
[Flight_tuning]
cruise_lift_scalar=1.000
parasite_drag_scalar=1.000
induced_drag_scalar=1.000
elevator_effectiveness=1.000
aileron_effectiveness=1.000
rudder_effectiveness=1.000
pitch_stability=1.000
roll_stability=1.000
yaw_stability=2.000
elevator_trim_effectiveness=1.000
aileron_trim_effectiveness=0.000
rudder_trim_effectiveness=0.000
hi_alpha_on_roll=1.0
hi_alpha_on_yaw=1.0
p_factor_on_yaw=1.0
torque_on_roll=1.0
gyro_precession_on_roll=1.0
gyro_precession_on_yaw=1.0
[GeneralEngineData]
engine_type=0
Engine.0=4.567,0.000,1.039
fuel_flow_scalar=1.477
min_throttle_limit=0.0
[Piston_engine]
power_scalar=1.0
cylinder_displacement=34.00 //73.9
compression_ratio=9.0
number_of_cylinders=4
max_rated_rpm=5800
max_rated_hp=60.000
fuel_metering_type=0
cooling_type=0
normalized_starter_torque=0.300
turbocharged=0
max_design_mp=0.000
min_design_mp=0.000
critical_altitude=0.000
emergency_boost_type=0
emergency_boost_mp_offset=0.000
emergency_boost_gain_offset=0.000
fuel_air_auto_mixture=1
auto_ignition=0
max_rpm_mechanical_efficiency_scalar=1.000
idle_rpm_mechanical_efficiency_scalar=1.000
max_rpm_friction_scalar=1.200
idle_rpm_friction_scalar=0.500
[Propeller]
thrust_scalar=1.5
propeller_type=1
propeller_diameter=5.330
propeller_blades=3
propeller_moi=3.000
beta_max=0.000
beta_min=0.000
min_gov_rpm=0.000
prop_tc=0.000
gear_reduction_ratio=2.27
fixed_pitch_beta=18.375
low_speed_theory_limit=80.000
prop_sync_available=0
prop_deice_available=0
prop_feathering_available=0
prop_auto_feathering_available=0
min_rpm_for_feather=0.000
beta_feather=0.000
power_absorbed_cf=0.000
defeathering_accumulators_available=0
prop_reverse_available=0
minimum_on_ground_beta=0.000
minimum_reverse_beta=0.000
[Electrical]
max_battery_voltage=12
generator_alternator_voltage=14
max_generator_alternator_amps=28
avionics_bus=0,3.5,9.0
avionics=1,3.5,9.0
additional_system=0,2,8.5
fuel_pump=0,5,6.0
starter1=0,50,6.0
light_strobe=0,3,8.5
[Contact_points]
point.0=1,2.70,0.00,-2.9,1500,0,0.575,30,0.13,2.0,0.8,0,0,0,0,0
point.1=1,-1.90,-2.70,-2.9,2500,1,0.575,0,0.13,2.0,0.8,0,0,2,0,0
point.2=1,-1.90,2.70,-2.9,2500,2,0.575,0,0.13,2.0,0.8,0,0,3,0,0
point.3=2,-4.10,-13.15,0.45,1600,0,0,0,0,0,0.0,0,0,5,0,0
point.4=2,-4.10,13.15,0.45,1600,0,0,0,0,0,0.0,0,0,6,0,0
point.5=2,-0.1,-11.70,0.00,1600,0,0,0,0,0,0.0,0,0,5,0,0
point.6=2,-0.1,11.70,0.00,1600,0,0,0,0,0,0.0,0,0,6,0,0
point.7=2,-14.20,-4.0,0.95,1700,0,0,0,0,0,0.0,0,0,9,0,0
point.8=2,-14.20,4.0,0.95,1700,0,0,0,0,0,0.0,0,0,9,0,0
point.9=2,-11.70,-3.75,0.95,1700,0,0,0,0,0,0.0,0,0,9,0,0
point.10=2,-11.70,3.75,0.95,1700,0,0,0,0,0,0.0,0,0,9,0,0
point.11=2,-14.60,0.00,4.90,1700,0,0,0,0,0,0.0,0,0,9,0,0
point.12=2,-13.30,0.00,4.70,1700,0,0,0,0,0,0.0,0,0,9,0,0
point.13=2,-12.70,0.00,-0.25,1800,0,0,0,0,0,0.0,0,0,5,0,0
point.14=2,4.96,0.00,1.00,1800,0,0,0,0,0,0.0,0,0,4,0,0
point.15=2,-2.80,0.00,2.95,1700,0,0,0,0,0,0.0,0,0,4,0,0
max_number_of_points=16
static_pitch=0
static_cg_height=2.3
gear_system_type=0
[Gear_warning_system]
gear_warning_available=0
[brakes]
parking_brake=1
toe_brakes_scale=0.75
[Exits]
number_of_exits=1
exit_rate.0=0.29
[Views]
eyepoint=-2.40,-0.81,2.06
[Radios]
Com.1=1,1
Com.2=0
Nav.1=0
Nav.2=0
Adf.1=0
Transponder.1=1
Marker.1=0
[Lights]
light.0=1,-2.70,-13.20,0.35,fx_navred
light.1=1,-2.70,13.20,0.35,fx_navgre
light.2=1,-2.75,-13.20,0.35,fx_strobe
light.3=1,-2.75,13.20,0.35,fx_strobe
light.4=1,-13.60,0.00,5.00,fx_strobe_ev97
[Keyboard_response]
elevator=100,180
aileron=200,1000
rudder=200,1000
[Direction_indicators]
direction_indicator.0=1,0
[Attitude_indicators]
attitude_indicator.0=2
[Turn_indicators]
turn_indicator.0=1
[Airspeed_indicators]
airspeed_indicator.0=1,0
[Effects]
wake=fx_wake
water=fx_spray
dirt=fx_tchdrt
startup=/
concrete=/
touchdown=/
[smokesystem]
smoke.0=4.567,0.000,1.039,ev97_fire
[Fuel]
LeftMain=-3.410,0.000,0.000,13.7,0.766
RightMain=-3.410,0.000,0.000,13.7,0.766
fuel_type=1
number_of_tank_selectors=1
electric_pump=1
[Airplane_geometry]
wing_area=105.920
wing_span=26.570
wing_root_chord=4.100
wing_dihedral=3.000
wing_incidence=3.000
wing_twist=0.000
oswald_efficiency_factor=0.770
wing_winglets_flag=0
wing_sweep=0.000
wing_pos_apex_lon=0.000
wing_pos_apex_vert=0.000
htail_area=20.990
htail_span=8.200
htail_pos_lon=-11.562
htail_pos_vert=0.935
htail_incidence=0.000
htail_sweep=0.000
vtail_area=10.760
vtail_span=4.070
vtail_sweep=34.000
vtail_pos_lon=-10.460
vtail_pos_vert=0.747
elevator_area=15.000
aileron_area=4.520
rudder_area=4.310
elevator_up_limit=25.000
elevator_down_limit=20.000
aileron_up_limit=20.000
aileron_down_limit=15.000
rudder_limit=30.000
elevator_trim_limit=25.000
spoiler_limit=0.000
spoilerons_available=0
aileron_to_spoileron_gain=0.000
min_ailerons_for_spoilerons=0.000
min_flaps_for_spoilerons=0.000
auto_spoiler_available=0
positive_g_limit_flaps_up=4.000000
positive_g_limit_flaps_down=2.000000
negative_g_limit_flaps_up=-1.500000
negative_g_limit_flaps_down=-1.500000
[Reference Speeds]
flaps_up_stall_speed=38.000
full_flaps_stall_speed=31.000
cruise_speed=90.000
max_indicated_speed=146.000
[Autopilot]
autopilot_available=0
flight_director_available=0
autothrottle_available=0
default_vertical_speed=700.000000
pitch_takeoff_ga=8.000000
max_pitch=10.000000
max_pitch_acceleration=1.000000
max_pitch_velocity_lo_alt=2.000000
max_pitch_velocity_hi_alt=1.500000
max_pitch_velocity_lo_alt_breakpoint=20000.000000
max_pitch_velocity_hi_alt_breakpoint=28000.000000
max_bank=25.000000
max_bank_acceleration=1.800000
max_bank_velocity=3.000000
max_throttle_rate=0.100000
nav_proportional_control=9.000000
nav_integrator_control=0.250000
nav_derivative_control=0.000000
nav_integrator_boundary=2.500000
nav_derivative_boundary=0.000000
gs_proportional_control=9.520000
gs_integrator_control=0.260000
gs_derivative_control=0.000000
gs_integrator_boundary=0.700000
gs_derivative_boundary=0.000000
yaw_damper_gain=0.000000
[Forcefeedback]
gear_bump_nose_magnitude=6000
gear_bump_nose_direction=18000
gear_bump_nose_duration=250000
gear_bump_left_magnitude=6000
gear_bump_left_direction=35500
gear_bump_left_duration=250000
gear_bump_right_magnitude=6000
gear_bump_right_direction=00500
gear_bump_right_duration=250000
ground_bumps_magnitude1=3250
ground_bumps_angle1=8900
ground_bumps_intercept1=5.0
ground_bumps_slope1=0.48
ground_bumps_magnitude2=750
ground_bumps_angle2=9100
ground_bumps_intercept2=0.075
ground_bumps_slope2=1.0
crash_magnitude1=10000
crash_direction1=01000
crash_magnitude2=10000
crash_direction2=9000
crash_period2=75000
crash_duration2=2500000
[stall_warning]
type=0
stick_shaker=0
[Flaps.0]
type=1
span-outboard=0.52
extending-time=1.8
system_type=3
damaging-speed=100.000
blowout-speed=120.000
lift_scalar=0.900
drag_scalar=0.800
pitch_scalar=0.300
flaps-position.0=0.000,0.000
flaps-position.1=15.000,0.000
flaps-position.2=30.000,0.000
flaps-position.3=50.000,0.000
[Hydraulic_system]
normal_pressure=0.000
[pitot_static]
pitot_heat=1.000000
[vacuum_system]
max_pressure=5.000000
vacuum_type=1
electric_backup_pressure=0.000000
engine_map=1,1,1,1
[pneumatic_system]
max_pressure=0.000000
bleed_air_scalar=0.000000
[deice_system]
structural_deice_type=0
