Hi everyone,
I have an interesting one for you, my evo joystick has started giving problems. First it started with taxing you would wander all over the place even with the stick still, on grass, runway, anywhere. Then the rudder control became over sensitive with heaps of over control from very small movements.
I reduced the sensitivity in the settings page and re-calibrated in windowes and FS and it was good for a short while but it has started again.049_sad.gif.af5e5c0993af131d9c5bfe880fbbc2a0.gif
Has anyone got any thoughts? Any help would be appreciated.
I use XP Pro, 2.8Ghz dual core, 4 gig DDR2 ram on a 160Mg HDD.
Bob.
THE FIX
Unplug the controller,
click Start
click Run,
type regedit and click OK.
In the Registry Editor open to the following folders in order:
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
MediaProperties
PrivateProperties
DirectInput
And delete the VID_06A3&PID_0464 folder.
Plug the controller back in, rotate the sticks a couple of times.
hope this helps others.;):thumb_up:
Bob.
