Marty_d Posted Monday at 11:15 AM Posted Monday at 11:15 AM Cargo plane skids off Hong Kong airport runway into sea, leaving two dead WWW.BBC.COM The Emirates flight EK9788 was arriving from Dubai when it hit a vehicle on the north runway. 1
onetrack Posted Monday at 12:06 PM Posted Monday at 12:06 PM Landing empty, and just skidded straight off to the left, and through the perimeter fence after touchdown? The airport security patrol car with the two victims was incredibly unfortunate to be in the wrong place at the wrong time. It's hard to understand how this runway departure came about, unless it was a brake malfunction, a reverse thrust mechanism problem on one engine, or a nose gear failure. Then again, it could've been some landing configuration error on the part of the crew. I recall a B777 that screwed up a landing in Munich, caused by crew confusion when using autoland. The B777 went all over the show, but still pulled up intact, and no-one was hurt! The initiator of the landing shambles, was localiser signal interference from a departing RJ85. Autoland Runway Excursion Blamed On Pilots AVWEB.COM German investigators say a runway excursion by Boeing 777 that was on autoland was the fault of the pilots. The unusual incident happened in November of 2011 1
facthunter Posted Monday at 10:29 PM Posted Monday at 10:29 PM All will be revealed. There should be plenty of Data and evidence. Nev 1
Moneybox Posted Tuesday at 12:56 PM Posted Tuesday at 12:56 PM Pretty accurate reporting... Emirates has confirmed to the BBC in a statement that flight EK9788 "sustained damage" on landing at the Hong Kong airport. You can always trust the media. 1
