T510 Posted May 26, 2025 Posted May 26, 2025 In preparing to reassemble my Supa Pup I was doing a thorough inspection of the wing struts and found a crack in one and a decent wear mark in another. Not having much luck finding a supplier for some replacements, anyone have any leads? Dimensions are 20mm x 47mm for the rear strut and 22mm x 50mm for the front one, both 2mm wall thickness. Cheers
BrendAn Posted May 26, 2025 Posted May 26, 2025 8 minutes ago, T510 said: In preparing to reassemble my Supa Pup I was doing a thorough inspection of the wing struts and found a crack in one and a decent wear mark in another. Not having much luck finding a supplier for some replacements, anyone have any leads? Dimensions are 20mm x 47mm for the rear strut and 22mm x 50mm for the front one, both 2mm wall thickness. Cheers what about rollo the aeropup man in queensland. don't know if aeropup will be the same but he might have access to a supplier. 1 1
