On the off chance that a Forum member, in the general area stretching from Newcastle - Sydney - Batemans Bay - Canberra - Cowra,  may be able to assist.
My Sonex is parked in the open, with only a Punkin Head Air Sport cover for protection. The cover is great but won't help if we get large hail.
I have been looking  to acquire a second hand Polytunnel frame or even an old (small) commercial chook house frame, with which to make a lightweight cover for Sonex.
Approximated dimensions (I can modify anything that is a bit small/large):
Wide 8 m x Long 8m x High (centre) 2m
Modular Broiler Poultry Shed at Rs 150 ...
Sorry Nev - not looking for construction suggestions, that is unless you have the frame to go with your corrugated sheet.😈
Nissan huts were not always constructed with frames .
Make your hut with the " cross " , in four sections,  tail feathers at one end ,
a wing section either side , then the nose section to complete the " cross " ,
With your baby safe inside ,
Not my design , but spotted at the Oaks .
spacesailor
spacesailor
Thanks Spacesailor,
Quite a few "interesting" innovative designs at The Oaks.
Being both lazy and tightfisted (unfortunate?), I am looking for something that already exists. Can be readily transported (after deconstruction) and reassembled with minimal modification. All at minimal cost (preferably Nil or even be payed to take away😁).
I would like to be able to work on my aircraft inside the structure - hence the ideas about tunnels & chook sheds.
You are possibly aware, "building permission" at The Oaks, is very strict, requiring the builder to not construct anything resembling a permanent structure.
I have a igloo shade house for my veggies the cover is from a orchard.. rain goes through but hail just bounces off
My plane got hit by a hailstorn in Narrabri, parked outside. The damage was on top and down one side (strong wind), so make sure you have the sides covered as well or enough distance to the edge.
  • Informative 2
  • 1 month later...
I'm a bit late to the discussion here, but if you look on eBay under "steel carport" or "steel garage", you'll find that 6.2M is the maximum span you can get, before you need to move to a steel or timber truss construction for your temporary hangar.
The bottom line is that any construction that requires 8M of span (and clear, unsupported span at the entry), won't be "lightweight", and you also need to consider just how to anchor the temporary hangar, as wind gusts will ensure it takes off like a kite, if it's not secured to the ground in a serious manner. 64 sq m of surface area is a giant kite just waiting to get airborne.
The nearest thing I can think of for your request, is the aluminium-truss portable marquees, that are normally hired out, and which run into a sizeable level of expenditure for something measuring 8M square.
You can occasionally find one for sale on the likes of FB or Gumtree.
WWW.EXTREME-MARQUEES.COM.AU
Plain and printed heavy duty gazebo, pop up tents, and marquee promotional banners for trade shows and events. Industry leaders over 10 years.
