A CFI got on me for adding flaps while in a turn the other day (turning base actually) and I am not sure why. I forgot to ask him about it after we landed.
So what is the concern there?
And what about when you are circling in from an instrument approach (not that we do instrument approaches in RAA aircraft) where you might be turning continously thru 270 degrees of the compass and end up right on very short final?
When would you bring in the flaps then, beyond the first notch just
before you start that big sweeping turn? there is no mention of
extending flap in a turn in the POH.
Oddly enough, this is one I learned back in the days of flying radio models.Once myself and on two other occasions watching others, I saw flapped models ( all scale) spin in while turning final to land from a small circuit.Turns out that you may not notice the amout of pitch change that can be associated with deployment of flaps, and even harder to notice while turning!So the situation is that if you are tuning (base or final) and you apply flaps, you are at approach speed (slower than cruise), you are turning (applying 'G'), you will feel the deceleration (which you expect)
but because you are turning, you are sensing many
rate-position-sound-speed changes, then you may NOT notice that you
have increased the angle of attack on the WING (not the fuselarge where you are sitting) and are getting close to a critical angle!The usual clincher is when you apply opposite aileron to roll out of the turn, and stall the inboard wing!The
nose drops, you instinctively pull back on the stick, and the ground
crew walks to the end of the strip to scrape up the mess!!!!Arthur.
Guest TOSGcentral
I had written the following before Arthur added his comments. I concur
with everything Arthur has to say but the stance I am taking is did the
CFI get excited about an actual error or what he considered a
procedural thing?
A point is if you have systems then you should be able to use them
sensibly without losing control – that is what pilots are supposed to
do! We could go to the giddy limit of saying ‘don’t lower flaps in a
turn because you may stall’ to ‘don’t retract the undercarriage because
you may forget to put it down’ and/or ‘don’t go to course pitch because
you may forget to set fine pitch for landing’. Why not just leave it in
the hangar then you cannot possibly make a mistake (other than retracting the gear)!
Anyway this is what I wrote last night but did not post as I have been putting an engine in a Thruster.
That is a disappointing post Ultralights! Seems like the ‘do it by the
numbers’ brigade are still alive and well – and adding to inhibitions
that cause accidents!
Let us take a bit of a look at this.
The only reason the instructor (be it CFI or otherwise) should have had cause to chip you on was if you had lost control (even partially) of the attitude/airspeed with the flap deployment attitude and drag change – and/or not been nudging flap limiting speeds.
Would have been different if you were putting them UP! That does tend to cause reasonable dismay when near the ground etc!
A lot of this sort of thinking stems from a stereotyped form of
instructing that I deplore! The ‘bible’ is the flying training syllabus
but so little work has been done on the difference between ‘what to
teach’ and ‘how to teach’ – not to mention what the purpose of the
training is anyway all about!
In the early days flying training has to be (to at least an extent)
‘by the numbers’. This is to enable students to come to terms more
easily with quite complex interaction between decision, judgement and
manipulative skills. So effectively the syllabus breaks things down to
a manageable flow for them as they learn to come to terms with the
workload and then master it.
As they master individual components the instructor should then be
schooling them into growing situational awareness and applied, safe use
of the skills they have learned. Unfortunately this does not often
happen! The syllabus is plodded through with various (alleged)
checking procedures that gives everyone a warm feeling, pilot
authorisation is given and then the pilot comes back later for a BFR
and nothing has changed!
You are still expected to fly by the numbers – not as an experienced
pilot with full control of the machine but as a raw student on a ‘by
the numbers’ exercise. I am not here excusing sloppy circuit procedures
if that was the objective of the exercise – but there are (and have to be)
applications of control that are not ‘bell book and candle’! I like to
see those being automatically put into practice when needs must. And
sometimes they really ‘must’.
Now, let us look at this flap situation.
The standard format for teaching GA style flap operation for landing (or it certainly was) came directly from early military flying training for much heavier aircraft that you could not afford to stuff about with!
This was deploy first stage of flap as part of downwind checks to start
bringing the airspeed and inertia under control. Second stage of flap
would normally be applied on base leg to safely lower speed further and
get to landing configuration. Full landing flap would then be deployed (mainly as a drag aid) to make aiming point management easier on the pilot.
This is of course the nice ‘square circuit’. Where the chips really go
down is when the donk has stopped and you are challenged to land the
damn thing with not very nice, or airfield sized, alternatives. You
also are (these days)
more likely to be flying something reasonably heavy that does not lose
speed easily and in fact picks up speed if the nose is lowered! Not
your average traditional ultralight!
If your particular challenge involves shortage of height, space and
distance etc to get into the most suitable area then you will find that
you are likely to be flying something termed the ‘constant angle
circuit’ to the aiming point. This is a continuing spiral path from
wherever you start to where you want to land because you have no
height, space or distance to do anything else! There can be little
‘square circuit’ about them at all.
In this situation the pilot has to fly the aircraft accurately and be master of its systems.
There is nothing particularly new about any of this – it is not only
commonplace – it was standard military practice for normal operations.
Pilots of long nosed piston fighters had to use it, as did Fleet Air
Arm pilots – so they could see where they were going. And they
certainly not only had to use flap but use a damn lot of it! And none
of this mattered as increasing flap lowers stalling speed particularly
in a turn where wing loading may be raising stall speed to meet your
current flying speed!
Without knowing the exact circumstances you relate I cannot really
comment much further. But I do have disquiet in a couple of areas.
There may be a need for your CFI to have a rebore to examine what he
thinks he is doing and why he is doing it! The second is my growing
concern that we are getting increasingly complex systems aircraft
available and not ONE THING is, or has, been done to ensure that our
instructors are capable of teaching those systems effectively. There is
not even a syllabus of training for them let alone instructor checking.
One reason why I handed my ratings in – I do not choose to be
associated with that sort of system! We each of us have our own views
on what we choose to do and that happens to be mine!
During my time in GA aircraft, i have noticed vast differences in
Instructors, most noticably in the Piper Archer, my long term
instructor taught me to reduce power on climb after 500Ft or after the
first turn away from runway heading, reduce to climb power and lower
the nose to increase speed, after he retired i moved to another school,
and on the first flight in the archer i did the same and was quickly
reprimanded! funny, it was OK for the first 30 hrs, taught by a very
high time ex WW2 millitary flyer, but it was not to be done with this
new more stricter school. they all hated the fact i would fly without
wearing a Uniform!! oh well....
This time with extending flap, was in an Archer, turning base.
On downwind, speed reduced to below the white arc (80kts)
then as i entered the turn i slowly pulled up the lever to first stage
of flap. i wont lower second or full flap till on long finals or on
base depending on Pax/fuel load, after established on base, speed was a
comfortable 75 Kts and all was well, the instructor basically said I
should not extend flap in a turn..... and that was it, nothing too bad,
but enough to get me thinking... the flight was a check flight after
getting my medical renewed. I hadnt flown in a GA aircraft for quite a
few months, but have been keeping regular in the jabiru.
Rob
I know the feeling, I started at one school and then went to a
better one but much further away where I was taught to bring the revs
back from 5800 to 5500 once I got to 500 agl. I had cause to go back to
the first school where I got vigorously told off for reducing power.
They said not to reduce power till you reach cruise altitude. Being a
naive student at the time I was very confused so I emailed Tech at the
RAA and Jeff Shepherd sent back to me:
Makes life tough when two instructors are so different.My view, and I cannot tell an instructor how to instruct, that is their domain.In me A/C i take off at 5800 rpm (912uls), approx 500 ftagl pull back to 5500 for theclimb to my cruising altitude then pull further back to 5000rpm for the cruise.These are Rotax recommendations, and remember 5800 rpm is max for 5mins,5500 rpm is continues operation.
So I decided to heed Jeff's advice and went back to my other school who taught me that way.
i have tried my best to not Unlearn what i was originally taught, i
would much rather the instruction from a high hrs WW2 pilot than a new
uni graduate just gaining hrs... a lot of stuff he taught was Not in
the book, but generally inproved my flying skills without increasing
the risk to the aircraft. i ahve even had 1 instructor tell me not to sideslip to reduce height on a high final on a short strip.....
Fortunatly all the Instructor i have encountered have been very good,
and didnt try to change my long learned techniques.... i had approx 300
hrs in Piper Archers and Arrows before discovering the then AUF.... i
was even banned froma well know syd flying establishment after taking
the Archer into The Oaks! first the CFI was annoyed at taking the plane
for 4 hrs and only logging 40 mins airswitch time, though that was my
mistake, and i accept the responibility, but i did make sure there was
no bookings after me, the second time i told him i went to the oaks, he
banned me from his flying school as the strip isnt long enough, funny
when my calculations i still had 400 mtrs of grass left, and in actual
fact, actually used LESS runway than planned! co-incidently, all my
flying gear was stolen from there the same day hmmmmm headests and all.
Simple fact was, i did all my Short field and rough field training at
Short fields! the Oaks, Wedderburn and even Yerranderrie! but the Bankstown guys wouldnt let me take their aircraft on anyting less than 3000 mtrs of concrete! hence my return to The Oaks and the discovery of the AUF.
I am truly thankfull for having found a great instuctor that taught me
to really fly.... and fortunatly i have found another RAAus Instructor
who is similar and will do things out of the ordinary to help his
students gain ever valuable experience.
Guest TOSGcentral
Lack of standardisation in flying training is a critical issue and has
some definable causes. Most of these revolve around the difference
between ‘what to teach’ and ‘how to teach’.
Adherents of non-standardisation usually base their argument on each
instructor being individual, but a qualified pilot, and so should
therefore be able to put it over the way most suitable for the
instructor.
This is true to an extent but while, as a group, instructors may not
make a very good co-ordinated choir – they should at least be singing
the same song! If they do not then it is the student who pays when
changing between instructors or schools – or a pilot on checks.
At best this may be just extra dollars, confusion or frustration. At
worse it could drive the student out of flying training or leave deep
seated flaws in the training that the later pilot may be relying on to
get out of trouble.
An enduring maxim is that ‘first lessons learned are the hardest to
budge’ is very true. In situations of extremis the pilot will
instinctively fall back on that early teaching and react accordingly.
It essential that they react the correct way and confusion between WHAT
individual instructors teach (rather than HOW they teach it) does not help one damn bit!
This sort of thing happens in even the best systems – you always seem
to have a few instructors who want to preach their own gospel but they
can be controlled and kept in line if there is a standard pattern
requirement that they can be checked and measured against. But what
happens when you do not have any system at all?
For the benefit of newcomers who are making an assumption on what they
perceive to be RAAus’ function, rather than what it actually does –
this is the reality:
The lynch pin of standardised training resides on a dual base of a laid
down syllabus to teach to and consequently how instructors are trained
to apply that syllabus. So the core of standards is actually held by
the Instructor Tutors – those people who train instructors.
OK, we have a basic flying training syllabus (sort
of and it is being rapidly outstripped by new requirements now entering
the area – flaps, variable pitch etc that have not been addressed yet,
and there are still no stated syllabi for entire classes of ultralights).
This problem is compounded by virtually no ultralight and/or
recreational pilot support reference material to underpin practical
training.
We have NO standardised instructor training syllabus! A would be Tutor
Instructor has to design their own instructor training syllabus and
submit it for RAAus approval. Every Tutor Instructor in the country
could have their own different syllabus. How do you check the
instructors they produce and measure them against a standard later in
their careers? More to the point how do you help them get back on the
rails if they have come off?
It all comes down to personal opinion and that is no way to run an
enduring, safe, flying training system because too many individuals are
involved and they each have their own opinion!
This is entirely in keeping with RAAus policy in practice. That
‘policy’ is we will lay down a standard objective but how the members
achieve that objective is up to them and is their responsibility!
In my time with AUF/RAAus there has been only one change in instructor
training. That was mandatory inclusion of 30 hrs Principles and Methods
of Instructing (PMI). But that was cocked up as well!
Again there was no laid down syllabus – authority was handed down to
‘Approved Persons’ some of which where not even flying instructors. It
was a requirement for Senior Instructors only – yet it was the ‘Junior
Instructors’ who needed it most! There was a two year period given to
achieve the requirement by your next instructor renewal. During this
period the Ops Manual changed and left a loop-hole that one person
found and stood on his dig, threatening legal action.
I wound up personally resolving that via an oral PMI examination that
demonstrated the individual knew enough to retain his Senior/CFI/PE
approvals but not sufficient to retain his Instructor Training approval
– which I took from him. Neither AUF nor he were really satisfied but
at least the requirement had been met and the situation resolved.
Nobody paid me for doing that, I don’t recall even getting thanks!
There are so many holes. An absolute classic is that a Senior
Instructor can gain an Instructor Training approval but you do not
require one to be a Pilot Examiner. Yet it is only Pilot Examiners who
can renew instructor ratings. How much sense does that make?
So we blunder on. Our basic flying training syllabi (those we have)
are falling further behind as we enter an entirely new area of aviation
that AUF was not designed to deal with, but never got to a point where
it could adequately deal with what it had! Coupled with this is a total
silence on any standarisation of instructor training, or even making a
move towards that goal!
In a few years we will have a couple of hundred non-standardised
instructors who will have churned out a couple of thousand
non-standardised pilots. How do we check those and against what?
Opinion and member responsibility? Charming!
It was not going to be this way. Had Mike Valentine lived he had plans
to bring in an AUF parallel to the GFA National Gliding School. That
body is responsible for setting and maintaining all aspects of basic
and instructor level flying training and practical, applied standards.
It would have brought in the Regional Operations Controllers (ROCs)
as practical components of initiating and maintaining training and
standards at Regional level. It would have taken three years to do.
Mike’s loss was far more serious than most people realise. Equally the
seriousness of the actual problems we face, that are going to increase,
and the level of effort required to resolve them, are not at all
apparent. There are so few of us who have specialised in this area and
do realise the implications over a broad picture.
So I am happy now running TOSG, flying my historical Thrusters, doing a
bit of development work and test flying. I do not mind being made
‘Resident Instructor’ of this forum, if I can help I will – kick me out
if I start boring you or going too deep.
Aye
Tony
Leaving aside the issue of inconsistant or non standardised training, I
see no problem of pulling flap on in a turn. In GA training it's taught
for tightning the radius of a turn.
I had been told not to do it because if you had a flap malfunction (asymmetric flap)
it would be harder to control. Fair call but chances are you'd be very
unlucky if you had conducted a thorough daily inspection.
In the real world as Cecil will probably agree (possibly anyway) flaps are used to tighten the radius of a turn (ag work)
standard for the Airtractor and probably for most of the ag planes is
to lower flap through the turn at the end of the paddock and retract it
again before recommencing the run. That why they have a flaps lever on
the stick.
In G.A. and I also use these for high performance ultralights I only
use oval circuits. Therefore there is no level segments that would
allow me to put flap down between downwind and short final, bit of a
problem really!
As most people have said it will generally be the instructors who haven't been out in the real world (away from a flying school) who reproduce these ghost stories which they told when the where learning to fly.
The only way you can find out if it’s one of these ghost stories or
something worth listening to is to ask questions as you have done and
if the person who is telling you can't give you a straight answer then
it’s probably just another story.
I had an assymetric flap deployment in a (heavy) C206 - the nature of the operation meant flap was usually deployed in the turn.
What I found was that I did not notice the assy flap until I lined up
for final - the aircraft was rolling and yawing all over the place (much of it thanks to my instinctive inputs to counter the roll). The touchdown point got shortened pretty smartly - after landing the problem was apparent.
As a result I now always visually check 'even' deployment with each stage of flap (where possible).
Guest ozzie
I've never experienced assy flap but i did have the flap retract by itself on short final. (DHC6 320) did not realise what was going on at the time. the cpt picked it up when he went to reset flap 10 deg(takeoff)
as we taxied in. i just thought i picked up some heavy sink and needed
a fair bit of power. landing seemed more solid touched down about 15kts
faster a little short with a longer roll and more time in reverse.
seemed a rubber seal let go and the flaps retracted from the slip
stream. ozzie. (i learnt from that)
Where to comment?I feel the urge to say something, but am not sure how to, without contradicting myself!This leads me to ponder, as an experienced pilot, how could I contradict myself talking about flying and instructing?The truth is, many of the points raised above are valid and sometimes equally so on both sides of the discussion.The real answer, I think, lies in the fact that flying is a very broad spectrum activity and trying to teach it 'by numbers' suffers from the numbers being economised somewhat to appese the book writers.I learned originally in gliders with the GFA, but this was after flying models for years previous to that.During my childhood, my father was a state winning competitve modeller and a gliding instructor.In
this enviroment, I learned all sorts of things about flying,
instructing, techniques and proceedures from listening to him and other
modellers/instructors.Now as a Senior Instructor, I am faced with trying to balance 'the numbers' against variations that I have to come up with on the spot to better demonstrate a learning stage to a student rather than repeating endlessly 'by rote', and hoping they eventually get the idea.To that end I find the only real method is EXPERIENCE.This brings me to one of my gripes being the advancement of instructors.To me, the amount of rote training required presently for pilots wanting to become instructors feels wrong.There
is too much emphisis on trying to achieve the required amount of
numbers, but no consideration on gained experience, we seem to be
trying to teach experience.This puts us in the position of having our new pilots asking the Seniors and CFI's if they can become instructors.With the GFA (in my day) it was more a case of the Instructors and CFI's watching the solo 'young guns' and deciding when and who was ready to go to an instructors course.This
may seem open to abuse and personality conflict, but the truth is, the
gliding movement is still looked upon as being the place with the best
instructional qualities, which is why the AUF was originally based on
the GFA concept rather than the CASA backed GA field.Things
I find out of place are like the fact a trainee instructor has to do
more two seat training with a CFI or Senior Instructor, than a student
needs to, to go solo!Becoming an instructor is about having
flying exprience, knowing what flying really is and the ability to
comunicate and control at the same time.Ideally we are looking for 'naturals'
and CFI's shouild be able to spot them, those that can only learn by
rote should maybe not apply and just stick to flying straight lines
through the sky by numbers.That's my stick in the hornets nest, it's getting late (I'm instructing tomorrow!) so it's off to bed. zzzzzzzzzzzzArthur.
Arthur - I think what you are saying is that the intangilble is just that - not tangible.
It does not translate well to the world of competency based training -
and I think you have actually identified the reasons, perceptions of
personality/character/whatever you want to call it entering the
decision process.
Personally, I think this is only natural as we are all human (most of the time). Competency assessment seems to remove all scope for promoting real talent whilst at the same time rewarding mediocrity.
Oops - Am I getting off the topic?
  • 2 weeks later...
Hi Crew
My first experience of Instructors was at Narromine about thirty years ago. There were two GA instructors available and one aeroplane, a PA28-140with a 150HP Lycoming and I got to go with whoever they decided. I also think that I was the only student at the time. I never saw or talked to another student. Unknown to me at the time there used be two planes the same butthe other plane had crashed into powelines not long before and burnt killing the two occupants. They were buzzing a farm house north of Narromine.
The instructor I got was trying to get his hours up to move on to better things. I did my TIF with the junior instructorand eventually after threehours of further lessons he gave up saying I was hopeless despite my doingexactly as he told me or so I thought at the time.
One of my problems is that being an engineering type I usually thoughtthat people like instructors meant what they said. I have since learnt that very few people can explain exactly what they mean when giving a set of instructions. Try explaining what you do in the last 50 feet of landing an aeroplane and getting it onto all three wheels and stopped.
The senior instructor took over and fourhours later sent me solo.
The main difference was that the junior instructorgave instructions of what to do and where to do it with no explanation of why whereas the senior instructor gave more explanation of why and how you did it.
This is not an easy task in the example of when you are approaching the threshold on late final with a student pilot. The student pilot initially thinksall this is easy or hard depending on the conditions of the day for that first flight and he wonders why it is not the same next time he trys it unless he has an instructor that tells him that every landing or flying experience will be unique or different.
As others have pointed out all this usually comes with experience but I think that that experience will be better interpreted by the pilot if he has some explanation given him so that he can make decisions as conditions change.
So the studenthas to learn to cope with the varying conditions and keep within the allowable parameters of his aeroplane and the rules of flying. So the instructor has to be able to give the student the ability to make the rapid decisions required.
Shortly after going solo, with 1 1/2 hours solologged,we moved to Leeton and as flying training in Griffith at the time was substantilly dearer than Narromine I took up gliding at our Brobenah airstrip with the Leeton Gliding Club. So I had to start again and cope withevery flight ending in a forced landing. I was still wearing the problems of that first junior instructor and it took quite a while to undo flying by the numbers and fly according to the conditions. So now I have given up club glider flying after about 192 hours glider time andfive hundred and fifty one (551) landings, it was a winch club, and taken up RAA flying in a Jabru with tricycle undercarriage again. That was a challege after years of taildragging gliders.
I still think that some instructors should give more explanations than they commonly do but of course the student pilot can be easily overloaded and the instructor has to know when to shut up. I am amazed at the tolerance and patience of instructors that I fly with.
I would probably be terrified if I were doing it.
Regards
This topic is another that highlites the true value of of this great forum. We have a diverse range of views and experiences between us.Teaching methods between Instructors differ greatly just like between School Teachers.School Students however generally do not have the same option that Student Pilots have whenchoosing a Flying Instructor. In my opinion a good student reads a lot and asks a lot of questions. A good Instructor willadvise the Student what to read and therefore prompt the student to ask the right questions.The Instructor recognizing the studentslearning ability is the key to developing the relationship required for a happy and successfull relationship which is the key to good learning.My point is always question your instructor if you are confused or a getting a different message.
Guest micgrace
Hi
Sounds like the very first instructor I went to. Because I couldn't even taxi in a straight line (taildragger) said your useless no point you doing any training.
I went to someone else and was solo in no time. Imagine his surprise when I landed at "his" airfield with my son on board a Drifter.
