Surfsup Posted February 28, 2023 Posted February 28, 2023 I have some books that may be of use for someone wanting to get their PPL. where would I post this? Pick up Manly 2095 1
spacesailor Posted February 28, 2023 Posted February 28, 2023 Quick, Can I somehow get them , I failed my RAA B A K, test on the what cause's icing. spacesailor Toongabbie 2146
Student Pilot Posted March 1, 2023 Posted March 1, 2023 On 28/2/2023 at 7:20 PM, spacesailor said: Quick, I failed my RAA B A K, test on the what cause's icing. spacesailor Ice 😁 1
spacesailor Posted March 2, 2023 Posted March 2, 2023 (edited) As it's Raa caturgary , I didn't think it would be 20,000 to 40,000 feet hight to get icing !. BUT The answer leaves a lot of worry , if the " moisture content " of the air gets as high as Darwin . With no tempreture equation involved . spacesailor Edited March 2, 2023 by spacesailor
facthunter Posted March 2, 2023 Posted March 2, 2023 Yes it's very dry at high altitudes unless you're near a Cb cloud. Highest humidity is in Tropical Maritime air masses In those conditions you could expect airframe icing at FL 180 approx. Carb icing at 25 degrees. ambient. IF you get that question again. I'm sure you'll get it right. It was a trick question. Nev
