kiwiaviator Posted February 18, 2023 Posted February 18, 2023 Jabiru 230C. It has a fuel pressure sensor hooked up to a light on the dash. Recently this light has been flickering in flight (without electric boost pump on) No indications of poor performance at all throttle settings. Instead of this red light, I would like to get an actual fuel pressure reading on my Dynon EMS. I have never been a fan of red lights that come on 5 seconds before everything stops. Can anyone steer me to an appropriate sensor? In the meantime, is there anything else I should be checking?
Old Koreelah Posted February 18, 2023 Posted February 18, 2023 I bought a fuel pressure gauge from Maj Millard and it has been useful for fifteen years. About thirty seconds before the fuel runs out, the needle gyrates wildly, giving you enough time to swap tanks. 1
kiwiaviator Posted February 19, 2023 Author Posted February 19, 2023 After a bit more research, I am looking at a Dynon Fluid Pressure Sensor Kavlico v2 15psi (103755-000) Recommended by Dynon to replace legacy sensors. 1
skippydiesel Posted February 19, 2023 Posted February 19, 2023 16 hours ago, Old Koreelah said: I bought a fuel pressure gauge from Maj Millard and it has been useful for fifteen years. About thirty seconds before the fuel runs out, the needle gyrates wildly, giving you enough time to swap tanks. I had a gauge that also warned me of fuel level - In my case the "needle' would gyrate & then flip to empty, as the tank got within about 2 L of full. I found this very useful when transferring fuel in flight. 1
Markdun Posted February 19, 2023 Posted February 19, 2023 This is what I use. I have them in two aircraft and over 200hrs with great results. Needs a 5V power supply. $30 https://www.ebay.com.au/itm/163191931141?mkcid=16&mkevt=1&mkrid=705-154756-20017-0&ssspo=xieIH1mFSHi&sssrc=2349624&ssuid=Shq9KlDPSE2&var=&widget_ver=artemis&media=MORE 1
