extralite Posted August 2, 2022 Posted August 2, 2022 Has anyone seen a pod/strut combination like this one before?
Methusala Posted August 3, 2022 Posted August 3, 2022 Great idea, means you can remove the pod without disassembling the airframe. Maybe related to the "Swift" project.
extralite Posted August 4, 2022 Author Posted August 4, 2022 I believe it is off an X-Air. (thanks kind stranger)....is it load bearing? Obviously be not as strong with the bend right? It does do the job in an X-air so a Thruster i think should be the same.
The Baron Posted August 26, 2022 Posted August 26, 2022 On 04/08/2022 at 8:34 PM, extralite said: I believe it is off an X-Air. (thanks kind stranger)....is it load bearing? Obviously be not as strong with the bend right? It does do the job in an X-air so a Thruster i think should be the same. It is a T600 pod
The Baron Posted August 26, 2022 Posted August 26, 2022 1 minute ago, The Baron said: It is a T600 pod It is fitted to a T500
