"The most successful aircraft in history the Cessna 172S is now rebuilt from scratch by Airfoillabs for X-Plane as New Generation Airfoillabs Product Series. You can expect unprecedented Study Level Simulation of C172S with G1000 Avionics."
3D Model
  • 3D Model based on real aircraft and rebuild from the ground up
  • Exquisite PBR Texturing
  • Lycoming IO-360-L2A with all engine parts
  • Engine Heater, GPU, Refueling details, Fuel Sampling, Oil Management
  • Covers, Chocks, Tiedowns
  • Interior with many animations, vibrations, zero-G floating objects, baggage, and more
  • Damaged Aircraft Parts
  • Many detailed passengers and pilots
  • Rain, Fogging, Icing, Broken Windshield
  • Custom Particles Effects
  • 48 Liveries
  • Countless additional details, features, and animation
  • HDR Lighting System
FMOD Sound
  • More than 320 sounds + detailed layered engine samples with audible failures simulation
  • Many real aircraft recording sessions
  • All animations, movements, and situations are producing sounds
  • Weather effects outside and inside of the aircraft
Flight Model
  • Based on real aircraft flight recordings
  • Performance tuned and correlated with performance tables
  • Behavior details consulted with Pilots and Flight Instructors
  • Additional custom behavior: Stall and Spin, Soft Field Takeoff, Crosswind Ground Operations
  • Lift, Drag, Moment Forces Airfoils Data customized by internal plugin-based tweaker
  • Detailed Damage Simulation as Bending of the wings, Overspeed Flutter, Flaps damage, etc.
  • Wing Tail and Fuselage ground strike simulation.
  • Flight Model is influenced by - Vortex Generators, Flap Gap Seals, Bush Wheels, Fairings, Broken Windshield, etc.
Aircraft Systems
  • Custom Fuel System Simulation including fuel flow and individual components logic and failures
  • Landing Gear plugin-based tuning of forces including Side Moments, Skidding, and more
  • Detailed Landing Gear Damage - Bending Struts, Tire Wear, Flat Tire, Brakes, etc.
  • Flight Controls Damage simulation
Electrical System
  • Plugin Based Custom Electrical System designed according to real C172 Electrical Scheme
  • Simulating All Circuit Breakers, Electrical Components Failures, Short Circuits
  • Custom Busses, Fuses, Corrected Voltages, Amps, Batteries, behaviors, etc.
  • Electrical Scheme 2D Panel with live states
Engine Logic
  • Plugin Based Custom Engine Components Simulation and Wear
  • Per Cylinder Simulation of Temperatures, Wear and Failures
  • Custom Oil Temperature, Pressure Simulation
  • Custom Per Cylinder EGT simulation
  • 2 Magnetos and 8 Individual Spark Plugs Simulations
  • Spark Plugs Fouling Simulation
  • Additional Engine Components Wear and Failure Simulation (Air Intake, Fuel Pump, Exhaust, Fuel/Air Control Unit, Fuel Flow Transducer, Oil Filter, etc.)
Failure Management System and Scenarios Saving
  • Custom Plugin Based Failure Management System
  • 175 Individual Components Simulated
  • Each Aircraft Component has a Wear property with custom Logic
  • Components Wear and Failures are influencing each other
  • Components State Saving Option
  • Failed at Altitude ASL/AGL Option
  • Possibility to Save Failure Sets as Individual Scenarios with thumbnail and description
  • 30 Scenarios Provided
C172 Knowledge Base
  • All of the failable 175 components are explained in detail in a 2D window
  • It provides valuable C172 information about how the aircraft works in real life
  • Engine Components are 3D clickable from the outside with Instant Descriptions, Explanations, and Illustrations.
User Interface and 2D Panels
  • New Gen User Interface with Floating Menu - Ergonomy and Ease of Use in mind
  • Instant Loading of Aircraft States: Cold&Dark, Before Start, Before Taxi, Before Takeoff
  • Detailed 2d panels with detachable windows for second monitors
  • PFD, MFD, Audio Panel, Switches Panel, Standby Instruments, CBs, Throttle Quadrant, Pedestal, Electrical System, Engine with animations 2D Panels
  • Aircraft Options Menu
  • Weight & Balance Detailed Options
  • Complex Failure Management System
  • General Settings include aircraft states, components conditions, sounds, intro, etc.
  • Custom Load/Save Situations Dialog
  • Remote Control for Airfoillabs Hangar at KAWO airport
  • Camera and Quick View Interface
  • Automated Checklists with Performace Calculators (Takeoff, Landing, Cruise)
  • Stylish Intro Animation
  • Cockpit Builders Optimized
G1000 additional features
  • Custom Engine Panel with Realistic Lean and System Tabs
  • Lean Assist Logic
  • Reversionary Mode Logic related to custom components
  • Custom Alerts, Caution, and Warning System
  • Speed Slip Improvements (Acceleration, V Speeds)
  • Simulating Loading Sequence and Instruments Initialisations
  • Custom Instruments Failures Warnings
  • G1000 Components Failures simulation
Aircraft Options
  • Wheel Fairings, Stylish Disc Wheel Covers, Bushwheels
  • Vortex Generators, Flap Gap Seals
  • Cockpit AoA Indicator and Tablet with AviTab Implementation
  • Headphones Logic and Noise Canceling
Checklist and Performance
  • Complex Automated Checklist System
  • Camera Focus on Instruments Option
  • Checklist Flow Options: Manual, Semi-Automatic, Automatic
  • Checklist Hints
  • Short Field Takeoff Calculator
  • Short Field Landing Calculator
Ground Operations
  • Manual Towing
  • Exterior Manual Check of Flight Controls
  • Covers, Tiedowns, Chocks Manipulation
  • Manual Fuel Sampling
  • Manual Refueling and Fuel Quantity Check
  • Manual Oil Refilling and Oil Quantity Check
  • Engine Heater Operation Logic
Walk Feature and QuickLook Camera with Collisions
  • Walk Feature with Terrain and Aircraft Collisions
  • Walk, Run, Crouch and Gravity Simulation
  • Climb on aircraft to refuel, get in/out
  • Customizable and Comfortable QuickLook System for Hat Switch Joysticks, compatible with other plugins
Source:
https://store.x-plane.org/C172-NG-DIGITAL_p_1523.html
