SGM Posted November 8, 2021 Posted November 8, 2021 (edited) As RPC and unaccustomed to flying over restricted areas, I thought I would check my understanding. If flying the below route from NE to SW.. - fly anytime except Tue, Thur, Sun at 1.15pm-1.45pm AEDT - radio call on 126.2 at 10NM to advise overflying, and maybe again as entering R330A (which is about 4nm from YMPC - Point Cook) - fly not above 2000 until ALTS (infact 2000 is the westbound guidance on this VFR route) - fly at 2500 (and not above) within R330A and R330B (given trainee circuits are probably being conducted at 1000) - radio call 126.2 when directly above YMPC - Point Cook - keep a sharp lookout given danger area and no ADSB (which is the recommendation) - Don't land (as I don't have permission), keep beacon and landing lights on - Did I miss anything? (slightly confused by the comment "status of MIL CTR/CTA are not included" as this is a MIL field) -------- Edited November 8, 2021 by SGM typo
turboplanner Posted November 8, 2021 Posted November 8, 2021 No, but did you give any thought to using the Light Aircraft Lane instead?
SGM Posted November 8, 2021 Author Posted November 8, 2021 (edited) Turbo, Did you mean continuing the Melb Coastal VFR route until the BOM tower then heading south from there? I was trying to fly the entire bay shoreline if I could. SGM Edited November 8, 2021 by SGM typo
turboplanner Posted November 8, 2021 Posted November 8, 2021 6 minutes ago, SGM said: Turbo, Did you mean continuing the Melb Coastal VFR route until the BOM tower then heading south from there? I was trying to fly the entire bay shoreline if I could. SGM OK, the LAL cuts the shore on the western side, but starts quite a way inland.
SGM Posted November 8, 2021 Author Posted November 8, 2021 If the above concept is ok, and there are not extra approvals required or misunderstandings about Point Cook, the only shoreline I can't get to as RAAus pilot would be the Mordialloc area due to Moorabbins 3NM radius.
