Guest chain52saw
Is anyone aware if Virgin Australia has fitted ADS-B to its remaining 737/7.
Occasionally a 73xx overfly's my location and doesn't appear on Flight Radar 24.
I noticed tonight, that a couple of 733, overflew my location (Moorooka, Brisbane, Australia)
and both were fitted with transponders.
I think that the Australian Air Express 733's are also not fitted with transponders. Can anyone confirm this information.
I have also noted that within the last 3 months that Cobran Air' 712's (badged Qantas-Link) have all had ADS-B transponders fitted .
Thanks
Guest Darren Masters
Most of the 737's should be fitted or in the process of having this implemented (along with the wifi onboard). :)
By what date must I be equipped wi
th ADS-B OUT to comply with the
new rules?
It depends. The current regulations require you to equip as follows:
Dec 2013: All operations at and above FL290
Feb 2014: Aircraft operated under the IFR first registered in Australia after 6 Feb 2014.
Feb 2016: In large parts of Western Australia (Airspace classes A, B, C and E).
(This is co-incident with the mandatory requirement to fit GNSS to all IFR aircraft for
navigation in Australian airspace.)
Feb 2017: All IFR operations at all flight levels
