Pricey Posted April 7, 2009 Posted April 7, 2009 Hi Guys, 1) Does anyone know when 07/25 at YSSL will be operational again? 2) Does anyone know a reason for UAL having the two colour schemes? Just curious...
Guest aviatrix27 Posted April 7, 2009 Posted April 7, 2009 TRIGGER NOTAM - AIP SUP H78/08 RWY 25 SAFETY ENHANCEMENT CONSTRUCTION OF RWY 25 RWY END SAFETY AREA AVBL FM AVFAX CODE 81005 AND AIRSERVICES WEBSITE http://WWW.AIRSERVICESAUSTRALIA.COM/PUBLICATIONS/AIP.ASP FROM 09 250813 TO 06 151600 EST If I remember how to read these things, that should mean 15th June
Guest Chainsaw Posted April 7, 2009 Posted April 7, 2009 Pricey, The old scheme is the gray/dark blue. The newer one is the light/mid blue. AS each plane has some serious maintenance done, it may have its skin repainted.
Tim E Posted April 7, 2009 Posted April 7, 2009 Hi Pricey..the two colour chemes had always fascinated me too..as UA 840 flies over my house every day it was one of the few big boys that I used to be able to spot here in Wangaratta..I was always determined would fly on it one day! I did some research a year or so ago on the colour schemes and found some info..if i still have it or the site I will pass it on.Tim
Tim E Posted April 7, 2009 Posted April 7, 2009 Just noticed I called the UA 840 plane a big boy. Have a feeling ships are girls aren't they?..How about planes..wonder if they are either / both boys or girls?
Guest aviatrix27 Posted April 7, 2009 Posted April 7, 2009 Planes are female Tim, with the possible exception of military aircraft.
Guest Chainsaw Posted April 7, 2009 Posted April 7, 2009 Unless it is gay (ummm happy gay lol) or one of those special 'trans' Pacific models LOL
Guest Darren Masters Posted April 7, 2009 Posted April 7, 2009 To answer the question of 07/25 June I believe is correct.
Guest David C Posted April 7, 2009 Posted April 7, 2009 Don't forget that N121UA a UA B744 is painted in the Star Alliance scheme too , so that makes 3 colour schemes !! Dave C
Pricey Posted April 7, 2009 Author Posted April 7, 2009 Antonov 225 female? I would think not guys... I have always thought anything smaller than a Jumbo was female, Jumbo or larger must be male. Then Qantas go and name an A380 Nancy...
Pricey Posted April 7, 2009 Author Posted April 7, 2009 Looking forward to 07/25 reopening. Moved to Bexley in July last year, right under the outbound flight path. Then they go and close it on me...
Tim E Posted April 7, 2009 Posted April 7, 2009 Much as I often say I love everything Irish..thats not quite true..that bloke Murphy and his Murphys law has a lot to answer for! Seems like he diddled you Pricey! Bad luck ! Oh well..it will be re-opening again. I'd be writing a letter to Mr Murphy if I were you. I have quite a stack of them here I should send..if only I knew his address.
Uncle Chop Chop Posted April 7, 2009 Posted April 7, 2009 Great Veiwing area under the Rwy 25 Approch path. I can remember sitting under their while the planes flew over head, smelling the Aviation Fuel and listening to the Jet's strut their stuff. AHHHHH the Memories.
