Guest Darren Masters
You sure did buster :biggrin: What advise worked?
Yes you see some interesting stuff on there. Once you use ACARSD though for ACARS you will never look back. It decodes with minimal errors.
some weird stuff coming up on this !!
F03A 7:58:02 PM 18/02/20094 2 Msg Label: H1...MESSAGE TO/FROM TERMINAL
Aircraft Reg: .VX-VXP
Flight No: QF0$&5
Message: #M1BPRG/
S39A 7:57:50 PM 18/02/20092 2 Msg Label: Q0...LINK TEST
Aircraft Reg: .VX-VXJ
Flight No: QF0038 Airline: QANTAS AIRWAYS
DOWNLINK NAK
S55A 7:41:22 PM 18/02/20091 M Msg Label: 5V
Aircraft Reg: .VH-VXN Country: AUSTRALIA
Flight No: QF0656
Using Ground Stat
ion: Manchester
Yeah it does that sometimes. It is not decoding the messages correctly. I'll tell you again, throw it in the rubbish and get ACARSD. You won't have that problem with ACARSD.
cant install it, system is locked down. Must be able to run without install. Plus ACARSD streams it for public use i dont want that.
Pity your system is locked down and you cant install ACARSD cause as Daz says its the best :biggrin:
I use it over here - it doesn't stream it to the public if you don't select those options, I've used ACARSD for nearly 2 years and never once has my stuff gone past my computer
  • 1 month later...
