Where is Aviation Going????
Guest g_i_jack029
Ok, this is a question that i've been thinking about myself lately.
Where do YOU think aviation is going to go, in regard to fuel prices.
Do you think we'll go to BIOFuel, Solar, Steam :roll: just anything like that.
so here's the question,
Where do you think Aviation is going to go, in regard to fuel?
and also
How much longer do you think that we can rely on the current fuel???
Guest g_i_jack029
i'm thinking Biofuel will be a hit for awhile but after that i don't know where the industry, actually not just the aviation industry but everything that involves burning fuel, after that i don't know where the WORLD will go!
A steam powered A380 !!!
Jack your job is to shovel the coal into the fire to keep the engines going !!
Guest g_i_jack029
A steam powered A380 !!!Jack your job is to shovel the coal into the fire to keep the engines going !!
it's possible!
Guest aviatrix27
Maybe you can convince Lycoming to let us use biofuels. They say if fuel containing alcohol is used, they will void our warranties. Apparently the alcohol component attacks all the rubber seals.
  • 1 month later...
Guest g_i_jack029
I think Solar might play a major part in aircraft eg. lighting, in my blog the "Antares" has a battery that would be nearly good enough for the airlines to use. using power from the battery then the battery can be charged any...nearly all the time.
Biofuel will be a major hit for a few years until the price of fosil fuel starts going through the roof (this all depends on if new oil reserves are found)
After this is what i want peoples opinions on, What will power our aircraft after the fosil fuel we use is gone?
Where will our industry go???????????????????????????????????????????
Will we still use the same aircraft?
Will we keep trying to make even more fuel efficient aircraft?
How will the prices stay in reach for a middle or even lower class families?
Will the price be extremely high?
Will there still be a shortage of pilots?
Will there still be a shortage of Air Traffic Controllers?
Will GA be affordable in 10 years?
Will flying on airlines be affordable in 10 years?
WHERE IS AVIATION GOING!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!????????????
Guest g_i_jack029
Grrrrrr, doesn't work Glenno :(
Glenno? your sounding like robbo
Stange that the link doesn't work for you. I copied the text below for you
"When you're in an airplane, you don't want your fuel to start solidifying," said Robert Dunn, a Department of Agriculture chemical engineer who is studying biodiesel jet fuel.The airline industry is aggressively pushing for homegrown alternatives to petroleum-based jet fuel, while leaning on customers with a variety of new travel charges to help control a projected $61 billion industrywide fuel expense this year. A number of alternatives to standard jet fuel have been studied for years, though aircraft manufacturers say the challenge is to find ideas that will work now.
Jet engines can be retrofitted to run on hydrogen, for example. But hydrogen does not pack the same punch as traditional jet fuel - kerosene - and would require airlines to buy planes designed with massive tanks. That is a tough choice for cash-strapped carriers, said Billy Glover, managing director of environmental strategy at Boeing Commercial Airplanes.
The best bet right now for non-conventional fuel comes from South Africa, experts said. The country has powered its airline industry for a decade using a coal-based jet fuel blend developed by petrochemicals group Sasol. It's technically a "synthetic" fuel, which means it can be used without altering engines or other aircraft equipment.
A number of U.S. companies are developing a variety of similar synthetics. Airline experts say three companies in particular could provide as much as three million gallons a day of synthetic fuel by 2012: American Clean Coal Fuels of Portland, Ore., Baard Energy in Vancouver, Wash., and Rentech Inc. of Los Angeles.
Though significant supplies will not be ready for several years, the Commercial Aviation Alternative Fuels Initiative (CAAFI) - a coalition that includes the Federal Aviation Administration, airline, manufacturing and airport associations - wants to set standards by the end of the year for a 50-percent synthetic jet fuel. CAAFI wants standards for a totally synthetic fuel ready in two years.
Executive Director Richard L. Altman said the push for new fuel standards is meant to show investors that airlines will buy synthetic fuel. Doing so will send needed dollars to energy startups that may one day replace foreign oil, Altman said.
"Nobody will invest unless the fuel is certified," he said. "So we have a bit of a chicken-and-egg problem."
With more companies investing in alternative energy, the thinking goes, the more synthetic jet fuel eventually becomes available. The more fuel available, the easier it will be for airlines to unshackle themselves from volatile petroleum markets.
Meanwhile, Boeing and Air New Zealand later this year will test a biofuel made from the oil-rich seeds of the jatropha tree, a Mexican plant that grows in warm climates. Other synthetic fuel tests will follow on Continental Airlines and Japan Airlines flights. In February, Boeing partnered with Virgin Atlantic to test a flight that included a biofuel mixture of babassu oil, which comes from a palm tree in northern Brazil, and coconut oil.
"We're looking for something that is so correct in its performance that it can be interchanged with petroleum-based kerosene," Glover said. "From a distribution standpoint, from a technical standpoint, it needs to fit without modifications or special handling."
Many biofuels may create more problems than they solve, however. Using edible feedstocks such as corn and sugar could raise the price of food. And palm trees for babassu and coconut oil could lead to clearing large chunks of rain forest.
These are some of the reasons why algae-based synthetic fuel is getting a lot of attention.
Algae is inedible, and it has a relatively high yield compared with other crops, using less land to produce the same amount of oil.
"It can be grown anywhere you can have a pool of water and expose it to sunlight," said Stanford Seto, an expert in aviation fuels who works with ASTM International, a Pennsyvania-based organization that develops standards for jet fuel.
Investors have pumped almost $84 million into companies developing algae-based fuel so far this year, up from $29 million in all of 2007, according to the Cleantech Group, an industry research firm.
Despite its promise, it will be years before algae biofuel could be sold at a price that would make sense to an airline, said Dave Jones, co-founder of LiveFuels, an algae fuel startup in San Carlos, Calif.
"If anyone is below $50 a gallon, I'd be stunned," he said. "We have a pretty good idea on how to grow algae. The biggest challenge is in the harvesting and how to extract it from the water."
Even if prices come down, most airlines see synthetic fuel as a chance to run a greener airline, not necessarily a cheaper one, said Nancy Young, vice president of environmental affairs for the Air Transport Association.
More fuel sources could temper the effect oil speculation has on gas prices, and they could give carriers fuel at a cost they can count on, she said. But "you aren't going to find a fuel that's pennies on the dollar than what we find today," she said.
For travelers, that means that fewer flight options and charges for checked bags, drinks and other items are here to stay.
"Even if we were to double the volume we were to make in biofuels every year for the next 10 years, we're still looking at maybe this will impact 15 percent of the overall fuel supply," said Brian Fan, Cleantech's senior director of research.
"Realistically, for anything to be happening at scale, enough to actually impact an airline's bottom line, we're years away," Fan said.
Guest g_i_jack029
Thanks Glenno 8)
That is really interesting!!!! LOL, i might be having a silly thought but if they used Hydrogen and to hold that Hydrogen they need big heavy tanks, wouldn't some of the hydrogen help take the weight??? this could be an embarrassing question when i hear the answer lol :lol:
so bio and synthetic fuel is the way?
i'm waiting for a completely different propulsion system to come out, but i think that'll be years away!
