Guest Glenn
Source: http://www.news.com.au/story/0,10117,19 ... 09,00.html
ASTRONAUTS have checked out flight systems on shuttle Discovery and stowed gear as they neared the end of a mission that may signal better days for the troubled US space program.
Discovery was scheduled to land on Monday at 9.14am Florida time (10.14pm AEST) at Kennedy Space Centre if the weather cooperates and the shuttle passes final inspection.
Mission Control communicator Steve Frick told Discovery the weather "looks generally pretty good" for a Monday touchdown.
"They are showing a chance of showers. It gets a little worse as the day goes on, so we're hoping the early morning works out for us," he radioed from Johnson Space Centre in Houston.
During tests on Sunday a leaking power unit for the shuttle flight control system appeared to be in good enough shape for landing and the jets that steer the spacecraft worked fine, NASA engineers said.
The shuttle crew was still awaiting word on whether the heat shield on Discovery had passed a final inspection performed on Saturday, but scans conducted with cameras and sensors throughout the flight had so far turned up no damage.
This 13-day mission was critical to a NASA still recovering from the 2003 disaster when shuttle Columbia fell from the sky after falling fuel tank foam cracked its wing heat shield during launch.
The space agency, after spending $1.3 billion and more than three years on safety upgrades, needed to prove it could safely fly the shuttle again and hopes that it did.
Flecks of foam, which insulates the fuel tank, flew off during take-off this time around as well, but NASA said they were too small and too late in the launch to be dangerous.
Discovery, making only the second shuttle flight since Columbia, docked with the International Space Station for nine days, during which astronauts Piers Sellers and Michael Fossum performed three spacewalks.
They repaired a broken transporter on the station which will be be needed to complete construction of the half-finished $100 billion complex and also tested shuttle repair techniques.
Discovery launched with seven astronauts on board, but left one of them -Germany's Thomas Reiter - at the space station where he will stay for six months.
NASA plans to fly 16 shuttle missions to finish the station, which is sponsored by 16 nations. The next flight is scheduled to take off around August 28.
Should the weather turn bad at Florida for Monday's landing, Discovery could be diverted to Edwards Air Force Base in California, which would likely delay its return by at least a day.
The shuttle has only enough oxygen to stay in space until Wednesday, NASA said.
