Downunder Posted August 9, 2018 Posted August 9, 2018 Fuel distribution is fine at proper rpm ranges 5000 to 5500. The carbs, inlet manifolds, cam and valves all come together in this range, especially after 5200. Up to 5000 the front two cylinder run rich and the egt's are significantly cooler but from 5000 onwards they even out nicely. 1
facthunter Posted August 9, 2018 Posted August 9, 2018 Alf, they "work" but not as well as they could. They have faults, some of which I have listed as I see them. It's not a complete list... People shouldn't buy them thinking they are "bomb proof". As they have made so many, the engine should have become cheaper as they amortise the development costs. They are good to fit a C/S prop on.. IF they have had a prop strike they need inspection. Drive runout is not a guarantee. I would like to see a bigger choice. of engine(s).in the market place.. and lower priced options. Makers have a big job producing something people won't muck up or fatally neglect with the idea it should run for X( X= 2,000) hours without a spanner on it or any checks needed.. Your tele might do that but a plane engine won't. It's environment is too unpredictable. . Nev
alf jessup Posted August 9, 2018 Posted August 9, 2018 Alf, they "work" but not as well as they could. They have faults, some of which I have listed as I see them. It's not a complete list... People shouldn't buy them thinking they are "bomb proof". As they have made so many, the engine should have become cheaper as they amortise the development costs.They are good to fit a C/S prop on.. IF they have had a prop strike they need inspection. Drive runout is not a guarantee. I would like to see a bigger choice. of engine(s).in the market place.. and lower priced options. Makers have a big job producing something people won't muck up or fatally neglect with the idea it should run for X( X= 2,000) hours without a spanner on it or any checks needed.. Your tele might do that but a plane engine won't. It's environment is too unpredictable. . Nev Nev, No engine is bomb or bullet proof, but as expensive as they are they are probably the most reliable overall engine for the Light sport / snowmobile range. The US military uses them in some drones and have clocked up many thousands of hours on them ( from memory over 10,000 hours) without changing them out. If we could get a cheap light 120hp turbine now that would be a good thing, other than expensive to buy and a triple fuel burn it would be something awesome. Alf
ev17ifly2 Posted August 9, 2018 Posted August 9, 2018 A person who buys anything mechanical thinking it's bomb proof should think again, especially if said machine has 2000plus hours. 1
Marty_d Posted August 9, 2018 Author Posted August 9, 2018 Alf, they "work" but not as well as they could. They have faults, some of which I have listed as I see them. It's not a complete list... People shouldn't buy them thinking they are "bomb proof". As they have made so many, the engine should have become cheaper as they amortise the development costs.They are good to fit a C/S prop on.. IF they have had a prop strike they need inspection. Drive runout is not a guarantee. I would like to see a bigger choice. of engine(s).in the market place.. and lower priced options. Makers have a big job producing something people won't muck up or fatally neglect with the idea it should run for X( X= 2,000) hours without a spanner on it or any checks needed.. Your tele might do that but a plane engine won't. It's environment is too unpredictable. . Nev I was under the impression that any engine that had a prop strike needed inspection.
facthunter Posted August 9, 2018 Posted August 9, 2018 Yes they check drive flange runout but I'm not sure it's adequate on a Rotax due to the press fit of the crank parts. Nev
facthunter Posted August 9, 2018 Posted August 9, 2018 Alf , I wasn't aware the 912 was used in snowmobiles. I wouldn't regard it as particularly suitable at all. Nev
eightyknots Posted August 9, 2018 Posted August 9, 2018 They have been around for nearly a century and snowmobiles are a big part of their history: A Look In The Fascinating History Of Rotax Engines
facthunter Posted August 10, 2018 Posted August 10, 2018 I am aware of their history but I specifically questioned the "912" being used in snowmobiles. Nev
