dominicm Posted June 27, 2018 Posted June 27, 2018 Smoke-EL is a microprocessor controlled smoke generating system that is lightweight, robust, and provides huge volumes of outdoor smoke for aircraft demonstrations. The system consists of a control unit with a G-Force sensor inside, smoke pump, and Fluid tank, and Heating Tubes to provide switchable and G-Force dependent smoke for your aircraft through the strategically placed Heating Tubes. These can be mounted in the aircraft center line, on the wing tips, under the cowling exhaust, or other places to create the effect you want. Gunter was flying a Krill 35% Extra 300 with 2.6m wingspan. Weight is 16KG. Power system is a Plettenburg Predator 30/6, Master Spin 220 Pro ESC, Gens ace 12S, 10000mAh LiPo, RASA 27 x 13 prop. PowerBox Mercury SRS with 2 x Jeti –SAT2 receiver’s RC battery 2 x 2800mAh, PowerBox LiPo. Thomas Lenard was flying a jet turbine engine powered CARF Models Eurosport equipped with the same G-Force enabled Smoke-EL system.
