sandman Posted April 27, 2018 Posted April 27, 2018 hey just seeing what sort of dollars I could get for a rotax 582 with 208 hours on it and I bought it 2010. It appears that the pto crank seal is weeping and the bottom angular pipe for rotary valve oil is broken, maybe someone who buys it might use it for parts but was thinking whether I get it rebuilt or sell it as is.
Alf George Posted April 27, 2018 Posted April 27, 2018 hey just seeing what sort of dollars I could get for a rotax 582 with 208 hours on it and I bought it 2010. It appears that the pto crank seal is weeping and the bottom angular pipe for rotary valve oil is broken, maybe someone who buys it might use it for parts but was thinking whether I get it rebuilt or sell it as is. hey just seeing what sort of dollars I could get for a rotax 582 with 208 hours on it and I bought it 2010. It appears that the pto crank seal is weeping and the bottom angular pipe for rotary valve oil is broken, maybe someone who buys it might use it for parts but was thinking whether I get it rebuilt or sell it as is. hey just seeing what sort of dollars I could get for a rotax 582 with 208 hours on it and I bought it 2010. It appears that the pto crank seal is weeping and the bottom angular pipe for rotary valve oil is broken, maybe someone who buys it might use it for parts but was thinking whether I get it rebuilt or sell it as is.
Alf George Posted April 27, 2018 Posted April 27, 2018 Is it complete with c type gear box ph 0263853131
Downunder Posted April 27, 2018 Posted April 27, 2018 I think the key thing is how it has been stored and when it was last run. It all depends on the crank brgs condition. 208 hrs is nothing, however any pitting, rust or damage to bottom end devalues it significantly. I personally know of a bottom end that did 1600 hrs, run several times per week in a trike.
sandman Posted April 28, 2018 Author Posted April 28, 2018 Just the motor, this motor has just been taken out and last run was 16 April 2018, I just replaced it with a new one.
rickodesu Posted April 30, 2018 Posted April 30, 2018 Hi, Ring me on (02) 6674 0235, Those hrs are not reallly high. Richard
Ben_luke9 Posted May 6, 2018 Posted May 6, 2018 Look up liquid intelligence seal rejuvenation. I added to my gearbox, as main seal weeping. 5 hours of ground runs and taxiing...all stopped now. Dropped the oil, replaced and safe tied and good as gold! Not cheap at $90 something, though I added to other engines I have at home to stop another leak too. Beats having to tear down and replace
farri Posted May 15, 2018 Posted May 15, 2018 I`ve had 4 Rotax 582 , all from new and currently running a Rotax 503 DCDI with E-type reduction gearbox. There`s no way I would use any additive, regardless of cost, to try and stop a seal from leaking...Keep in mind what the cost of an E.F.A.T.O. can be! Frank.
mph7 Posted May 17, 2018 Posted May 17, 2018 I will give you 2k for it, only because i have a spare motor !!! I know you said you wanted 3.5k but its just not worth it. Let me know ?
