Rhys1701 Posted August 1, 2024 Posted August 1, 2024 3 hours ago, Red said: I keep meaning to get to Sackville then something else comes up (Broken foot at the moment hence all the posts in here), will you keep her there? G-BMET is coming up to live in Welshpool She'll be in Sackville until mid August .. but once I have her we'll be going all over the place. One man, one airplane, one tent - unlimited adventure. 1
facthunter Posted August 2, 2024 Posted August 2, 2024 Rhy's, square wingtips etc are crap compared to the original design. Nev
Red Posted August 2, 2024 Posted August 2, 2024 19 hours ago, Rhys1701 said: G-BMET is coming up to live in Welshpool She'll be in Sackville until mid August .. but once I have her we'll be going all over the place. One man, one airplane, one tent - unlimited adventure. Some lovely grass strips around the Welsh Borders, have fun 1
Rhys1701 Posted August 2, 2024 Posted August 2, 2024 9 hours ago, facthunter said: Rhys, square wingtips etc are crap compared to the original design. Nev Negligible difference on a light aircraft with less power than a fly's fart and a cruise speed of a brisk jog .. It's not like it's been designed for every 1% efficiency for a M0.80 cruise at FL35 A study in 1971 even shows there's such a tiny difference: cruise and stall speeds altered by only a couple of mph for an assumed 55hp homebuilt aircraft http://acversailles.free.fr/documentation/08~Documentation_Generale_M_Suire/Conception/Dimensionnement/Aile/Comparison_of_square_round_and_Hoerner_wing_tips.pdf It just boils down to cosmetic appeal and individuality
Mike Walling Posted August 2, 2024 Posted August 2, 2024 One of my favourite Monos from the '70's was G-BEVS which was first shown at Sywell. The Last photo I've seen is 2013.
Teggles Posted August 2, 2024 Posted August 2, 2024 GINFO says the permit ran out in 2022. Anyone with more up to date knowledge?
Don J Posted August 2, 2024 Posted August 2, 2024 (edited) Teggs. What about those rudder and elevator cables any head way. Diehl wings from a KR-2 is the way to go. Nice taper and lots of aileron. Edited August 2, 2024 by Don J
Teggles Posted August 3, 2024 Posted August 3, 2024 Hi Don, No not yet. I will get the rudder and elevator on after I have finished the hinges and then use some string to see just how big a problem I have got!
Don J Posted August 3, 2024 Posted August 3, 2024 (edited) 1 hour ago, Teggles said: Hi Don, No not yet. I will get the rudder and elevator on after I have finished the hinges and then use some string to see just how big a problem I have got! Rudder cables probably won't be too bad but depending on where elevator cables fair leads are positioned that may be a headache. Do you have support blocks on Horizontal Stab and rudder post at hinge locations? Also don't forget Sheet 2 of prints section C-C showing the balsa in center of spars under the fabric I almost forgot those, and gap would have been terrible. And keep in mind you need room for hinge pins to come out at least one side by the balsa on center of spars.👌 Edited August 3, 2024 by Don J 1
Teggles Posted September 7, 2024 Posted September 7, 2024 Just having a celebration cup of tea (I am British). Hinges made and rudder on with no binding or play - and it’s straight! Yes there is more to do, but you have to take the wins when they come 😁. 3 1
Don J Posted September 7, 2024 Posted September 7, 2024 What is the plan on mounting the vertical Stab to the tail post? Are you going to use the hinge bolts? Don't forget those balsa strips that go on the leading edge of the rudder spar and elevator before fabric. Just think my friend only a few hundred things to do.🤪 Keep at it and keep use posted. DJ 1
Teggles Posted September 7, 2024 Posted September 7, 2024 That’s a good thought, I was thinking of separate bolts for the vertical stab but combining them with the hinge is a good idea. I have the balsa for gap sealing, so that will go on in the next few days. 1
Don J Posted September 7, 2024 Posted September 7, 2024 The top rudder hinge would be an easy transfer of holes to the VS you do have two bolts holding the hinge half on? Are you going tail skid or wheel? I used self-locking tee-nuts on the inside of my VS and HS along with elevator spar to ease in mounting and un-mounting of controls. then left enough thread to pass t-nut to add a ny-locking nut for further safety. Access holes had to be incorporated to pass a wrench inside to hold nuts and fabric patches will cover them for future access. How is the cable routing going? Hope all is well and happy flying Teggles. 1
Teggles Posted September 7, 2024 Posted September 7, 2024 I have yet to start on the VS, but will look at using the hinge bolts to secure it. I will have a tail skid, lots of grass strips around here and will save a little weight. Cable routing….as you say the rudder should be straight forward but the elevator I am trying not to think about 😂😂 1
Rhys1701 Posted September 17, 2024 Posted September 17, 2024 On 07/09/2024 at 6:41 PM, Don J said: Access holes had to be incorporated to pass a wrench inside to hold nuts and fabric patches will cover them for future access. Would you happen to have a couple of photos of this please? I'm looking to convert mine from tail skid to steerable tail wheel
Don J Posted September 17, 2024 Posted September 17, 2024 6 hours ago, Rhys1701 said: Would you happen to have a couple of photos of this please? I'm looking to convert mine from tail skid to steerable tail wheel Page 2 you will see the access holes are for the ability to get to the hinge bolts of the elevator and rudder hinges the tail wheel is a stock Scott full swivel type and activated by rudder horn.
Teggles Posted October 8, 2024 Posted October 8, 2024 Here’s a thought, anyone know of a short wingspan mono? JT states on the plans that the wing can be reduced by 1 bay (12.5 inches) from the tip. Ailerons stay the same. The stall speed will increase, roll rate a bit quicker? A little lighter? 1
Don J Posted October 8, 2024 Posted October 8, 2024 Believe me Teggles with your fuel capacity and with the lower hp a shorter wing will not be liked. Now if you put a 0200 on it with shorter wings, we may find a spot at Reno air races going fast and turning left.😉 1
Teggles Posted October 9, 2024 Posted October 9, 2024 I am not so sure. It’s a 10% reduction in span but if I can keep the weight under control then the wing loading will be less than that. Why does John Taylor mention it on the plans? He must have done the numbers and was happy with it. 1
Don J Posted October 9, 2024 Posted October 9, 2024 4 hours ago, Teggles said: I am not so sure. It’s a 10% reduction in span but if I can keep the weight under control then the wing loading will be less than that. Why does John Taylor mention it on the plans? He must have done the numbers and was happy with it. Not sure of the reason either but I would guess it may have something to do with the length of the root spars option regarding placement of Main landing gear mounts. You can mount at root spar or wing root. 1
Teggles Posted October 9, 2024 Posted October 9, 2024 To be honest I am just kicking around ideas. I don’t have much contact with other Taylor Mono owners as they all seem to live on the other side of the UK from me. So as my build progresses, just trying to see what other people think. It’s part of the fun of the build 😁 2
Teggles Posted October 16, 2024 Posted October 16, 2024 Warm day here in the UK, so that random it’s a glue day! Replacing the rear spar on the Mono’s tailplane. 1 1
Don J Posted October 16, 2024 Posted October 16, 2024 Looks great Teggles. It's a shame that all that gets hidden under plywood. Don't forget those hinge blocks on the inside of spar and I also mounted T-nuts before final ply was added. 1mm ply is tougher than I thought it would be to wrap around the leading edge but some soaking in hot water and a heavy 2" pipe worked wonders. Keep at it friend and keep us posted. 1
Don J Posted December 18, 2024 Posted December 18, 2024 Hello everyone. Build of the Taylor monoplane is still going great and closer every day. Been watching all these drone issues on the east coast of the USA. Not too sure what to think of it but I hope it's just kids having fun. Hope you all have a good holiday season. Don 4
Marty_d Posted December 18, 2024 Posted December 18, 2024 They're finished Taylor Monoplanes up there having fun, just waiting for you to join them! Have a good xmas Don. 2
