Hi could someone tell me if the bolt pattern on the prop hub of a Rotax 912 ul or uls is different to a rotax 914 please
Cheers Geoff.
I believe there maybe a difference between very early 912 and later, 4" as opposed to 100mm. Not sure when they changed. Perhaps a call to floods will confirm or otherwise about a difference.
On the later model Rotax engines the bolt pattern is different to the earlier engines. One of them is a bolt circle of 100mm dia and the other is 4" (101.6mm), but I can't remember which one is which.
Thanks for your information all sorted now couldn’t work out why my prop wouldn’t fit bolt pattern a lousy 1.6 mm difference .
