Bernie Knight Posted May 21, 2017 Posted May 21, 2017 I've seen a number of options for storage of those loose items such as phones, glasses, maps, beacons etc. What have you found the best storage options - net type pockets, metal storage or elastic topped pockets in vinyl etc... .?? The above photo has a number of net type pockets and a larger net in the rear storage. I wonder where you get those nets? - auto shops etc.. Any ideas of photos of how you store those loose items old be appreciated..
djpacro Posted May 21, 2017 Posted May 21, 2017 A typical solution for Pitts pilots Nomex USA Flight Suit 3
peterg Posted May 21, 2017 Posted May 21, 2017 [ATTACH=full]50431[/ATTACH] I've seen a number of options for storage of those loose items such as phones, glasses, maps, beacons etc.What have you found the best storage options - net type pockets, metal storage or elastic topped pockets in vinyl etc... .?? The above photo has a number of net type pockets and a larger net in the rear storage. I wonder where you get those nets? - auto shops etc.. Any ideas of photos of how you store those loose items old be appreciated.. Bernie Here's what I use in the Club Gazelle: iPad Bag - clips stitched on with whipping twine (very strong) & bag clips on to door lock rods & is easily accessible Bag contains - iPad Mini, Casa kneeboard (ERSA entries, flight plan forms, paper for notes, A/C specs & speeds etc in plastic sleeves). pens, rope, electrical ties, water bottle (CASA gift & when filled clips on to door lock rods), iPad lead, oil funnel, charts (VNC etc), mini multi tool, mini first aid (bandaids, steri strips, betadene wipes, panadol etc), sunglasses, pens Headset bag has a clip and attaches to A/C structure behind pilot's seat and is accessible in flight - contains headset, PLB, large Leatherman, spare batteries
Jaba-who Posted May 22, 2017 Posted May 22, 2017 Guess it depends on if you can make fixed changes to the aircraft or not. If you can there are a number of automotive "organisers" that can be either used as is or modified and hard-attached. I got some from autobarn or supacheap which I've attached to the inside of the doors in the jab 430. I must admit haven't seen the same model lately but I'd guess similar ones will do the same job. They are a couple of layers of pockets with some mesh and some fabric. Have worked well for 10 years.
eightyknots Posted May 22, 2017 Posted May 22, 2017 Guess it depends on if you can make fixed changes to the aircraft or not.If you can there are a number of automotive "organisers" that can be either used as is or modified and hard-attached. I got some from autobarn or supacheap which I've attached to the inside of the doors in the jab 430. I must admit haven't seen the same model lately but I'd guess similar ones will do the same job. They are a couple of layers of pockets with some mesh and some fabric. Have worked well for 10 years. I have seen these items at $2 shops from time to time as well.
Bernie Knight Posted May 22, 2017 Author Posted May 22, 2017 Thanks again. I'm going on the look out today.
peterg Posted May 23, 2017 Posted May 23, 2017 Thanks again.I'm going on the look out today. Try Yacht Chandlers as well - I'm reasonably sure Whitworths in Melbourne stock elasticised storage netting and there are a couple of good chandlers in Geelong that would be worth a try.
peterg Posted May 23, 2017 Posted May 23, 2017 Thanks again.I'm going on the look out today. Also, OXLEY NETS Pty Ltd 20 Network Dr, Port Melbourne VIC 3207 Ph 1300 730 731 will make to order using normal net any size you like with shock cord on whatever edges you wish. They have done stuff for me in the past and they are both professional and reasonable.
Soleair Posted May 23, 2017 Posted May 23, 2017 Here's my baggage bay, built behind the main bulkhead. I bought the elasticated net on fleabay - they're used on motorbikes.
Roscoe Posted May 23, 2017 Posted May 23, 2017 [ATTACH=full]50431[/ATTACH] I've seen a number of options for storage of those loose items such as phones, glasses, maps, beacons etc.What have you found the best storage options - net type pockets, metal storage or elastic topped pockets in vinyl etc... .?? The above photo has a number of net type pockets and a larger net in the rear storage. I wonder where you get those nets? - auto shops etc.. Any ideas of photos of how you store those loose items old be appreciated.. Hi Bernie can you give me a step by step guide on how to upload photos to forum posts? I'm ok with text and email but a bit lost with this website Thank you
Bernie Knight Posted May 23, 2017 Author Posted May 23, 2017 Once your complete your text you have the option to "Upload a File" Next to the "Post Reply" button. You will get an option on photo size. 1
Bernie Knight Posted May 23, 2017 Author Posted May 23, 2017 The only limiting point is the file size. It tells you if it's too large. Good luck
Roscoe Posted May 23, 2017 Posted May 23, 2017 The only limiting point is the file size. It tells you if it's too large.Good luck Ta
M61A1 Posted May 23, 2017 Posted May 23, 2017 A typical solution for Pitts pilots Nomex USA Flight Suit And Drifter pilots..... 2
