Knowns and unknowns
Crystal icing is deadly because unlike normal
icing, it is hard to detect or predict, and we
have no defences against it
Crystal icing is implicated in a growing number
of insufficiently explained crashes
below freezing up to zero – a sign that ice was
building up on it.
Crucially, Ratvasky was able to confirm the
association between HWIC and convective
storm systems, and identify the mechanism:
the strong updraught from the storm sweeps
water vapour to much higher altitudes than
normal. The effect does not seem to appear
when the convection is strongest, but when
the storm is dying down, for reasons we don’t
yet fully understand.
The hope is that all the data gathered will
yield a distinct signature that corresponds to
HWIC. This will enable “now casting” – using
satellite data to predict where aircraft are
likely to encounter dangerous conditions.
Researchers are also working on modifications
to existing radar that allow them to detect
crystal-icing conditions.
That’s a few years away, but at least it’s closer
than a full engine redesign. What’s more, the
team managed to establish a makeshift HWIC
detection method: by pointing the aircraft’s
weather radar downwards, you can see if you
are flying over patches of heavy rainfall and
should consider changing course.
Even better, Fuleki and his team have
cleverly hacked existing instruments to create
two sensors. The first, a beer-can-sized device
called the particle ice probe, is mounted
outside the aircraft and detects the presence
of small particles by the way they change the
air’s electrical characteristics. It was originally
designed to detect debris from the engine,
but the team modified it to distinguish the
particular signal of ice crystals.
The other device – an ultrasound ice accretion
sensor – directly measures ice
inside an engine. A series of dime-sized
sensors sends ultrasonic pulses whose
reflection changes as ice builds up. Both
devices are advanced enough that Fuleki
is now in talks about turning them into
commercial products.
Even when planes get the new sensors and
radar, however, we’re not out of the woods.
For one thing, we are still not done tallying
up the true toll of crystal icing. Speculation is
building on its role in yet more unexplained
crashes, such as that of Air Algérie flight 5017
in 2014, which killed 116 people.
We know about flight 447’s blocked pitot
tube because of the flight recorder, but with
some other incidents we may never know
for sure. Sometimes there is characteristic
physical damage, but aside from that, all
traces of crystal icing tend to vanish below
10,000 feet, whether the plane survives or not.
There’s even a chance the problem could get worse. The warmer, moister world
predicted by climate change will have more
convective instability, “ says Sue Gray, a
meteorologist at the University of Reading,
UK. “These systems will be more vigorous
and more frequent.”
And according to a recent analysis by
Rolls Royce engine labs, these increases in
extreme weather could make the conditions
in which crystal icing flourishes more
frequent. In a presentation, Rory Clarkson,
an engine specialist with the company, offered
an inconvenient but undeniably safe answer:
“Restrict operation during severe weather.” ■
Smart pilots avoid the big storms. This can use more fuel. Airline managements don't want you to use more fuel. You might not be carrying it either. In some airlines the pilot (although he/she has the responsibility by law) get the fuel load from the company. If you want to carry more you can be under a lot of pressure and even get the sack. That makes others think twice before being brave. Nev
As in many things, the bean counters measure short-term impacts of decisions. Does the airline's balance sheet put a price on safety? Some operators are more profitable and have more demure cabin staff, but I'm happy to pay a little more to fly with the world's safest airline; where it matters, Qantas people get it right.
After reading all that first post I am left wondering. What is crystal icing and HWIC?
