dutchroll Posted January 10, 2015 Posted January 10, 2015 Not that RA aircraft do a lot of formation stuff, but it was suggested to me that I should post this example from the 70s of how not to fly a formation rejoin. 1. You rejoin along a line slightly below the lead, not at the same altitude. That is, the lead aircraft should gradually move slightly vertically upwards above a fixed spot in the window as you get closer. If things turn pear-shaped, this allows the wingman to fly "through" the lead aircraft even if neither aircraft take avoiding action (in which case the lead will always pull up, and the rejoining aircraft will always push down). 2. You achieve only a moderate overtake speed during the rejoin process, then stabilise the rejoin position slightly loose, still maintaining an altitude slightly below the lead aircraft. 3. You move "up" (co-altitude). 4. You move "in" (the correct close formation position, nice and gently). "Altitude, line, speed" is the general "patter". It takes a lot of conservative practice before you can achieve a crisp, efficient formation rejoin. 2 1 2
facthunter Posted January 10, 2015 Posted January 10, 2015 I wondered when that would emerg again. Nev
Downunder Posted January 11, 2015 Posted January 11, 2015 I wondered when that would emerg again. Nev Why? Was it you? sounds guilty......(ducking for cover) 1
poteroo Posted January 13, 2015 Posted January 13, 2015 Formation joinups are possibly the most difficult for the beginner. There's a need to do it 'quickly' but not unsafely. As DutchRoll said - you must keep the target aircraft well above the horizon as this gives a clear view, and also allows you to bleed off some excess speed by pulling up into the correct level, usually as 'step down'. Never allow just 'anyone' to join up with you - maybe their skills have dropped off a la Captain Ansett in the vid. happy days,
facthunter Posted January 13, 2015 Posted January 13, 2015 Downunder, not likely. I am not a great encourager of formation flying especially when people are not current, or trained properly in the first place. I was flying F-27's with the opposition the year before that happened. You don''t get much closer to disaster than that one. Nev 2
Bennyboy320 Posted January 13, 2015 Posted January 13, 2015 Hmmmm, by the looks of it the captain had no formal formation training at all, bet the quality of the brief was the same as the join up, a complete cluster f***.
facthunter Posted January 13, 2015 Posted January 13, 2015 The Captain would be able to see Bugga all from where he sits, in that manouver. Nev
Bennyboy320 Posted January 13, 2015 Posted January 13, 2015 If done properly echelon left rejoin in a transport is not a problem from the left seat.
poteroo Posted January 14, 2015 Posted January 14, 2015 If done properly echelon left rejoin in a transport is not a problem from the left seat. The 'properly' bit is rather important! happy days,
rankamateur Posted January 14, 2015 Posted January 14, 2015 What happens if a tight formation is achieved, then they hit turbulence?
DingerPPC Posted January 14, 2015 Posted January 14, 2015 I know what would have been tight,their bum holes
facthunter Posted January 14, 2015 Posted January 14, 2015 Large formations did it during the last war, while getting shot at. Nev
poteroo Posted January 14, 2015 Posted January 14, 2015 What happens if a tight formation is achieved, then they hit turbulence? The theory is - that if you are really close, the 'formation' is equally affected by air movements. My experience is that it works ok for an element of 2, or a flight of 4 in diamond - but if any wider, then it tends to break up the formation. Remember, we're talking about aircraft with MTOW's here of < 1000 kg. The RAAF PC9's have much higher weights and wing loadings - and are less affected by turbulence. This helps them to achieve very steady formations - but a lot of very disciplined training goes into it too. happy days, 1
dutchroll Posted January 14, 2015 Author Posted January 14, 2015 If done properly echelon left rejoin in a transport is not a problem from the left seat. We used to fly close form on Caribous every now and again. The rejoin wasn't that hard if, as you say, you did it correctly. Mind you it was difficult to get much overtake on lead in a Caribou! :) 1
PA. Posted January 15, 2015 Posted January 15, 2015 If they touch they are too close, if they don't touch they aren't close enough. 1
