IF you don't burp or fart you will get a real gut-ache, most times. The pressure change is about 8.6 Psi max Your first concern is hypoxia, if you are above FL 120. Nev
It's must be true, why else would they supply everyone with those little yellow plastic oxygen masks.
  • Haha 2
  • Caution 1
Hey, Nev. Why don't you stand up while you read posts here. PA's reply went right over your head.
OME
  • Haha 4
Gasp!
Wait, what?
IF it did you are adding an oxidant to a fuel (This stuck and is therefore 10 hours behind where intended) Nev
