Why would want to JN?
Don't know about others but starting on one mag is a loft softer with the rotax also with shutdown always one shut off just before the other seems a fair bit gentler
I want to install the Bullyhawk soft start module which requires one mag to be not operating at startup.
T
There were also issues with Rotax mags not firing at low RPM. You only found out one had failed when the second failed (starting on both mags).
I now start on alternate mags.
A few threads on this forum about it I think.
Personally, I don't think you can beat individual mag (toggle) switches and a starter key/button..
  • Agree 3
The ACS switch comes with instructions for starting with only one active mag, which is the usual configuration on lycoming engines.
If I remenber correctly there is a link wire to connect to another terminal - so it earths out the unwanted mag when the key is turned to "start"
The ACS switch comes with instructions for starting with only one active mag, which is the usual configuration on lycoming engines.If I remenber correctly there is a link wire to connect to another terminal - so it earths out the unwanted mag when the key is turned to "start"
Terrific Jetboy, that is what I wanted to hear.
