Terrific! Anyone know what the engine is? Doesn't look like it is running on castor oil at any rate.
Its a modern Aero engine from memory but I believe Andrew wants to replace it with one of the Rotary engines they are building in NZ.
Nice plane. 2 questions.
Is that the fuel tank between the wheels?
What are the wooden "handles" for on the tips of the wing?
Guest Maj Millard
Big congratulations Andrew...and nicely flown also ! Very authentic looking aircraft .....great job.
The handles on the lower wing tips are to keep the wings out of the dirt !
I believe it is just a fairing for the axle to reduce drag.
Thanks guys. Re the 'fuel' tank question, at one point in the taxi sequence, the though I saw a filler cap but it must be an illusion.
Guest Maj Millard
On some German types the 'wing' on the axel had a couple of spikes attached to its rear edge. By pulling on a cable attached to the foward edge, the spikes would contact the ground for braking, as few of these aircraft at the time had any wheel brakes fitted..................Maj....
