seb7701 Posted November 26, 2013 Posted November 26, 2013 Can anyone assist as to whether anyone does a/c engine dyno testing in Qld? I found one in SA, but was interested in whether there is anyone is Qld who could get a power rating on a Rotax 912 which is having some issues. Long story, but this would solve one of the arguments for sure...
facthunter Posted November 26, 2013 Posted November 26, 2013 Lot of trouble. I don't know when one would be used. Why not remove a prop from a performing motor and put it on yours unchanged and compare performances. Revs would do. Dyno's are better to compare rather than give absolute figures too. Probably not the answer you are after . Nev
Guest Maj Millard Posted November 26, 2013 Posted November 26, 2013 Why the hell would you need a dyno for a 912.?.....now I've heard it all !.............Maj.......
planesmaker Posted November 26, 2013 Posted November 26, 2013 Easiest way as Nev suggested get a fixed pitch prop made for the 912 and check the static revs. Best if you can compare to another engine. Static revs should be around 5400 or so. Tom
bexrbetter Posted November 26, 2013 Posted November 26, 2013 I would chase up the Formula Vee car racing guys and ask. Similar sized engine and range of power so the dyno guy might be more accomodating to you.
airangel Posted November 27, 2013 Posted November 27, 2013 Just go to Jabiru.......They have a Dyno 1
