facthunter Posted October 1, 2013 Posted October 1, 2013 Bit like how you check a gas system for leaks. Pressure applied and soapy solution used. In this case the cyl head has cracked at the shrink band I would suggest. Try it with a Jabiru cylinder head to cylinder joint that hasn't been tensioned correctly. Nev
Guest Maj Millard Posted October 1, 2013 Posted October 1, 2013 Yes that is a point where cylinder heads can crack and separate, and have done in the past. Guess that is one way to find them, other than a close visual inspection ............Maj......
facthunter Posted October 1, 2013 Posted October 1, 2013 Usually when they crack there the whole thing (top part) comes off shortly after. Nev
