Remember the old petrol station pumps had a sight-glass with lots of brightly-coloured plastic beads twirling around? They told you the fuel was flowing thru to your vehicle. On the assumption that they actually floated in the petrol, I could use a pair of these in my sight tubes, so I can see the fuel level. Does anyone know where I can get some?
Have a look at bearperkins.com and click on the link for the catalog. They are called fuel floatees. About $5-$6 each from memory.
Kev
W
Have a look at bearperkins.com and click on the link for the catalog. They are called fuel floatees. About $5-$6 each from memory.Kev
Wow Kev, thanks for prompt reply!
How frustrating! After years of looking for these pellets, I find them. Spent thirty minutes filling out the online form, but can't see a "checkout" button. Maybe the site is not iPad-friendly. Eventually I got cut loose and had to start again.
I'll wait until I get home and use the desktop.
If you have any problems with the order page just send Bear an e-mail at the contact address and tell him what you want. Lots of good stuff there at very competitive prices. Have dealt with Bear before and I doubt you will get better service.
Kev
  • Helpful 1
I think you will find that the fuel flow rate in your aircraft is too small to show with those pellets, the way it does in a bowser. However, I have successfully used a Rotameter - See http://en.wikipedia.org/wiki/Rotameter to measure in-flight fuel flows; I made a suitable one with a piece of 25 mm Perspex rod, a tapered reamer (one of the devices sold by Radio Spares etc as a tapered chassis reamer will serve) and a 1/8 inch countersunk-head aluminium rivet. I reamed the hole so that the rivet could just drop right through without jamming, and used some wire mesh (about 1 mm holes) at each end to stop the rivet from escaping. I tapped each end of the piece of Perspex rod to accept a brass hose barb, and soldered the mesh to the threaded end of the barb. I positioned this vertically with the rivet head uppermost, so the flow lifted the rivet.
The bore of the perspex after reaming looked opaque - but that disappeared when it was wet with fuel.
Of course, if you locate this where you can readily read it, this probably means you will have exposed fuel-system components in the cockpit - not a smart idea; also it's a modification to the fuel system, so it needs formal approval if it's in a certificated aircraft. This is probably the reason you do not normally find this sort of hardware in aircraft.
Thanks for that, Dafydd, but like 503 says, it's the fuel level we need to see. My site tubes are in the wing, just visible from where I sit, but next to impossible to see in flight, unless there is a bright plastic bead in the sight tube floating on top of the fuel.
Thanks Kev, I have been looking for these for ages too.Old K, the submit button is way down the bottom.
Rick
I found it, Rick, but it led nowhere. Hours later I received an emailed invoice which I paid. Should have waited to make a bulk order to save postage and handling, which brought the price of three (one spare) pellets to $21 US.
