Admin Posted May 13, 2013 Posted May 13, 2013 Here is a snap shot of the new Recreational Flying Aircraft Showcase that is coming within the next few days to the site. The site home page will also include the "Featured Aircraft" What I would like to hear any comments on are the categories that I have created for the aircraft to enable you to find aircraft that are of interest to you. The proposed categories are simply: Ultralight and LSA Aircraft Microlights and Trikes Rotorcraft Powered Chutes Gliders GA Aircraft Warbirds, Vintage and Classic Aircraft Kits Is it to condensed or is the category list ok? 1
Bandit12 Posted May 13, 2013 Posted May 13, 2013 Experimental? Or if Kits are there, Plan Built as well?
shu77 Posted May 14, 2013 Posted May 14, 2013 It would be great if there was a way to standardise the specs, like the Aircraft directory Mag. Nothing worse than lusting after an airframe and then finding its a 472Kg MTOW or cruises 30 knots slower than you would have liked ...
Admin Posted May 14, 2013 Author Posted May 14, 2013 It would be great if there was a way to standardise the specs, like the Aircraft directory Mag.Nothing worse than lusting after an airframe and then finding its a 472Kg MTOW or cruises 30 knots slower than you would have liked ... What "standard" specs would you like to see every aircraft have...if a certain spec can't be ascertained, the standard spec would still be displayed but simply have an "unknown" next to it until such time that it can be ascertained.
facthunter Posted May 14, 2013 Posted May 14, 2013 Put "actual" and then list things like Basic weight AUW Cruise Speed and fuel rate of use, and VNe Structural and other limits ie +6 -3 G ultimate Fuel capacity location and material used for tank. Cockpit width Stall clean/ flaps ext. x-wind limit. Wingspan and area Construction materials used throughout Date built. Control system actuation. Rods, Cables Wheel brake type and make Tyres size.. Instrumentation and radio installed... Engine type/hours and airframe prop. hours. Where stored and used . Damage history... Something to start with.....Nev
Admin Posted May 14, 2013 Author Posted May 14, 2013 A lot of that isn't going to be available Nev, when I am populating the Aircraft Showcase section. I will only be able to go with what is listed on their websites.
facthunter Posted May 14, 2013 Posted May 14, 2013 True but if you establish a reference it might become more used. Mines only a start. (Deletions are OK so it could be reduced if that suited the purpose). What I have listed is some of what I would want to know. Nev
shu77 Posted May 14, 2013 Posted May 14, 2013 There was a file I PM'ed you a file last year which had: Name, Manufacturer, price, Cruise Speed, Max speed, Range, Useful load and Take off Distance for 86 types. Personally I would also like to see MTOW, Fuel Capacity, empty weight. The world directory of leisure aviation here includes: Empty weight, MTOW, Vs0 Vcruise & engine. Any combination of the above would be great, I'f you can import from a spreadsheet Im happy enough to consolidate one entry from the two sources.
Admin Posted May 14, 2013 Author Posted May 14, 2013 There was a file I PM'ed you a file last year which had: Name, Manufacturer, price, Cruise Speed, Max speed, Range, Useful load and Take off Distance for 86 types.Personally I would also like to see MTOW, Fuel Capacity, empty weight. The world directory of leisure aviation here includes: Empty weight, MTOW, Vs0 Vcruise & engine. Any combination of the above would be great, I'f you can import from a spreadsheet Im happy enough to consolidate one entry from the two sources. I don't recall the file Shu77 UPDATE...found it
Admin Posted May 15, 2013 Author Posted May 15, 2013 One issue I am finding is that many aircraft web sites list a Stall Speed of their aircraft with no qualification. What would you guess it to be when an aircraft has in its specifications just the heading of "Stall Speed"...would you take it as Vs or Vso or ???
Admin Posted May 15, 2013 Author Posted May 15, 2013 I have come up with these pre-set fields for the Specifications page of each aircraft...any other specifications can be entered in as extra text: Cruise Speed (Vno): Maximum Airspeed (VNE): Stall Speed (Vs): Fuel Capacity: Fuel Range: Useful Load (kg): Take Off Distance (ft): Wingspan (ft): Engine Make/Type:
damkia Posted May 15, 2013 Posted May 15, 2013 I have come up with these pre-set fields for the Specifications page of each aircraft...any other specifications can be entered in as extra text:Cruise Speed (Vno): Maximum Airspeed (VNE): Stall Speed (Vs): Fuel Capacity: Fuel Range: Useful Load (kg): Take Off Distance (ft): Wingspan (ft): Engine Make/Type: Prop Make/Type (Number of blades, Fixed pitch/Ground adjustable/CSU)
Admin Posted May 15, 2013 Author Posted May 15, 2013 Prop Make/Type (Number of blades, Fixed pitch/Ground adjustable/CSU) Thanks damkia however that information normally isn't always listed without having to start up dialogue with the distributor...where it is provided on the distributor/manufacturer's website, it can be included in the text information on the specifications page
Admin Posted May 15, 2013 Author Posted May 15, 2013 Well, I have added the first aircraft into the Recreational Flying Aircraft Showcase to see how it all goes. Please have a look and before I start populating it properly, any comments are welcomed
Guest Howard Hughes Posted May 15, 2013 Posted May 15, 2013 MTOW Basic empty weight. Baggage capacity (volume & weight) All very important for any initial aircraft consideration.
