Phil Perry Posted April 18, 2013 Posted April 18, 2013 Rotax alert THE CAA has released an Emergency Mandatory Permit Directive (eMPD) relating to some Rotax 912UL, 912ULS and 914UL engines. The directive mandates a cylinder head inspection for certain serial numbers for a manufacturing defect that can lead to catastrophic failure of the engine. A Rotax Alert Service Bulletin mandates that the inspection be conducted before the next flight. Hi Guys. . . This information is BOUND to be available in Australia too, but if you have not seen it, Links are available to the MPD on the latest BMAA E news . [email protected] Phil 1
Gentreau Posted April 18, 2013 Posted April 18, 2013 Is this the one that requires a sparkplug inspection for oil ingress ?
Phil Perry Posted April 18, 2013 Author Posted April 18, 2013 Is this the one that requires a sparkplug inspection for oil ingress ? No Clive, This is related to manufacturing defects in the cylinder heads on some of the 912 and 914 engines, and the alert is issued for a Mandatory Permit directive for inspection. Phil
rgmwa Posted April 18, 2013 Posted April 18, 2013 I think you may be referring to this one: http://legacy.rotax-owner.com/si_tb_info/alertbulletins/asb-912-062-ul.pdf rgmwa
Phil Perry Posted April 18, 2013 Author Posted April 18, 2013 I think you may be referring to this one:http://legacy.rotax-owner.com/si_tb_info/alertbulletins/asb-912-062-ul.pdf rgmwa Possibly RG, I have not read either of them thoroughly,. . . no need at the moment, as my engine isn't covered by the alert, but thanks for the heads up mate, appreciated. Phil
Gentreau Posted April 18, 2013 Posted April 18, 2013 Phil the latest ASB on Rotax-owner.com is this one: http://legacy.rotax-owner.com/si_tb_info/alertbulletins/asb-912-062-ul.pdf While the fault is with the cylinder heads, the mandatory inspection is of the spark plugs.
Phil Perry Posted April 18, 2013 Author Posted April 18, 2013 Phil the latest ASB on Rotax-owner.com is this one:http://legacy.rotax-owner.com/si_tb_info/alertbulletins/asb-912-062-ul.pdf While the fault is with the cylinder heads, the mandatory inspection is of the spark plugs. OK Clive, I just sent this out, as I didn't see any references to it on any of the forums, and I thought it said something about a manufacturing fault in some cylinder heads. . . . . . My 2 aircraft don't use the four stroke Rotax units, one has a continental, and the other ( microlight) has a 2 stroke 503. . . . .) Just trying to be helpful. . . . ( ! ) Phil
Yenn Posted April 25, 2013 Posted April 25, 2013 Go to CASA website and you will be able to arrange for all AD's to be sent to you. I get them and am lucky I don't own a chopper as most of them apply to fling wing.
