J170 Owner Posted June 4, 2012 Posted June 4, 2012 TTIS = total time in service but what does TSO mean?
damkia Posted June 4, 2012 Posted June 4, 2012 TTIS = total time in service but what does TSO mean? Time since overhaul
Guest Maj Millard Posted June 4, 2012 Posted June 4, 2012 Time Since Overhaul.......!...........................................................................Maj...
J170 Owner Posted June 4, 2012 Author Posted June 4, 2012 Thanks - I have these 'memory things' every now and then. Scared stupid I'll turn up at work in nothing but my jocks.
Guest Maj Millard Posted June 4, 2012 Posted June 4, 2012 The visuals there are just plain ugly !.......................................................................Maj...
motzartmerv Posted June 4, 2012 Posted June 4, 2012 Yes the TSO column in Jabiru engine log books is always empty....;).... 1
Guest Maj Millard Posted June 4, 2012 Posted June 4, 2012 Motz, wouldn't it be TSLU...............Time Since Latest Upgrade ?...............................................................Maj...
facthunter Posted June 4, 2012 Posted June 4, 2012 The meaning of zero timed, overhauled, reconditioned, rebuilt etc can be many things to many people. In my view (and many others) the only zero timed engine is brand new. Very thorough inspection and overhaul can approximate it. I don't know how anybody can measure metal fatigue easily. Total time in service seems pretty clear. Time Since Overhaul (TSO) has relevence with props magneto's it can be hours in service or time (years) since overhaul/ inspection. Shelf life can be a factor limiting the product's useability., too. Sometimes Time To Run (TTR,) is used. Complex innit? Nev
damkia Posted June 4, 2012 Posted June 4, 2012 TTSLFU Guess........ Usually very short for me at work.........
Guest Maj Millard Posted June 4, 2012 Posted June 4, 2012 1 minute ????.....................................................................Maj...
Tex Posted June 4, 2012 Posted June 4, 2012 Thanks - I have these 'memory things' every now and then. Scared stupid I'll turn up at work in nothing but my jocks. As long as you remember your jocks:blink:
damkia Posted June 4, 2012 Posted June 4, 2012 J170 Owner said: ↑ Thanks - I have these 'memory things' every now and then. Scared stupid I'll turn up at work in nothing but my jocks. As long as you remember your jocks:blink: I wouldn't worry, I'm sure it'll be a Saturday............ 1
damkia Posted June 4, 2012 Posted June 4, 2012 1 minute ????.....................................................................Maj... Are you SURE you haven't met me???
Guest Maj Millard Posted June 4, 2012 Posted June 4, 2012 Mmmm, don't think so !!??...................................................Maj...
Gnarly Gnu Posted June 4, 2012 Posted June 4, 2012 Also means 'technical standard order' e.g. TSO'd instruments etc per FAA.
Guest Howard Hughes Posted June 4, 2012 Posted June 4, 2012 I only wandered in here because I thought the thread title was 'TITS and ASS'...
kaz3g Posted June 5, 2012 Posted June 5, 2012 Thanks - I have these 'memory things' every now and then. Scared stupid I'll turn up at work in nothing but my jocks. Sounds positively scary! But I can relate to the memory thing. I seem to be working harder now than almost anytime in my life and I have so many things running through my mind at once, I too have embarassing memory lapses. I now find I have to make notes, more comprehensive notes, about where each of my clients matters are at. Sort of like check lists when we go flying... I think we are all (speaking generally) working longer and harder than ever before. At least it should help keep Alzeimers at bay! Kaz Kaz
Guest Maj Millard Posted June 5, 2012 Posted June 5, 2012 How long is a piece of string Yenn !!....................Different engine manufacturers and engine shops have different ideas on what constitute an overhaul. Often it is spelled out clearly by the engine manufacturer in the Engine manual.Some want the engine the engine rebuilt to 'new' specs, some just require that it meets certain tolerences, some want new crank and bearings, new cylinders ..the lot, as good as new...........................................................Maj...
damkia Posted June 5, 2012 Posted June 5, 2012 So what is the definition of overhaul? IIRC replacement of all friction surfaces ie all jugs, pistons/rings, bearings, cranks, valves/seats, etc - anything that has a wear component built in - with new, or used products that are within new specs, whilst keeping compnents that do not have an intrinsic wear pattern such as conrods, cylinder heads, and crankcase, on spec (subject to rigourous inspection though). Basically an almost "As new" motor. "Zero timed" is where the core (crankcase only) is used and all components are brand new on top of that. Happy to be corrected if this is not right (been a while...)
dazza 38 Posted June 5, 2012 Posted June 5, 2012 So what is the definition of overhaul? The definition is, how many used parts a engine overhaul business can get away with installing into a engine and getting away with it.And saying buy me. I am overhauled.(Hawker Blue seal engines come to mind).Long story, but the Newly o/h Hawker Blue seal engine we put in hour Piper Archer, was a piece of crap compared to the "old" 2000 hour TX engine it replaced.
eightyknots Posted June 5, 2012 Posted June 5, 2012 I only wandered in here because I thought the thread title was 'TITS and ASS'... Wrong website Howard!
Gnarly Gnu Posted June 5, 2012 Posted June 5, 2012 .... I have so many things running through my mind at once, I too have embarassing memory lapses. I wouldn't stress about it Kaz. What's the worst that could happen? Some poor sucker end up incarcerated who otherwise wouldn't have been, no big deal. Besides it's not like you'd remember to even feel bad about it!
