farri Posted December 8, 2011 Posted December 8, 2011 Tex, In my earlier post, I forgot to mention that my top tank, ( I have the aluminum one ), gravity feeds into the belly tank and I`ve run the vent hoses from both tanks, high enough up the the verticle post, just behind the top tank, so that no fuel can escape. Cheers, Frank.
fly_tornado Posted December 8, 2011 Posted December 8, 2011 I have 2 tornado 503's the one with premix suffered from rotting fuelines and insulation on the wiring below the carbs. I am guessing modern fuel lines aren't designed to handle the acidity of 2 stroke oil
farri Posted December 8, 2011 Posted December 8, 2011 I have 2 tornado 503's the one with premix suffered from rotting fuelines and insulation on the wiring below the carbs. I am guessing modern fuel lines aren't designed to handle the acidity of 2 stroke oil ft, I`ve never had rotting fuel lines in 26 years,but of course, everything has a use by date and it needs to be replaced before it goes rotten! Otboard motor fuel line shouldn`t go rotten as most 2 stroke motors use premixed fuel....I`m currently using that type of fuel line and it`s been on for 4 years. Frank.
fly_tornado Posted December 8, 2011 Posted December 8, 2011 I will keep that in mind, it looks like generic Aircraft spruce fuel line. My wiring below the carbies was really dangerous, wires poking out of the insulation.
skyfox1 Posted December 9, 2011 Posted December 9, 2011 Hi Few years ago l used the blue fuel line from Wade Air and it cracked in two months of use, now l use automotive injection fuel line on my 503 and have never had problem in three years. cheers Geoff..
fly_tornado Posted December 9, 2011 Posted December 9, 2011 farri, its "clear" polyurethane fuel line
farri Posted December 12, 2011 Posted December 12, 2011 ft, that`s what I thought! I`ve seen that type of hose, from the supplier you`ve mentioned, go what I would call rotten, in just a few months, when being used as fuel line. The hose I`m talking about, developed a lot of bubbles within the wall and some were blackish in colour. This hose could have failed at any time, allowing the fuel to escape. Frank.
