The 28hp model could possibly suit 95:10 aircraft that performed satisfactorily with a Rotax 277 , the Winton Swing Wing for example, however there are very few 95:10 aircraft around and the Sapphire was better equiped with the Rotax 447.
Alan.
The 28hp model could possibly suit 95:10 aircraft that performed satisfactorily with a Rotax 277 , the Winton Swing Wing for example, however there are very few 95:10 aircraft around and the Sapphire was better equiped with the Rotax 447.Alan.
There seems to be a fair number still around... and as a build project 95.10 seems like the perfect category... the problem seems to be the lack of Rotax 447 engines left in circulation with no real alternative.
Thanks for that Ozzie... That Valley Engineering engine looks great... All the hard work done and a good price.
you aren't going to get too far on 28hp!
At the end of the video the specs stated that the engine was 40 hp.
I like it and at that kit price we could start a squadron of them. Bring on the 95:10:thumb_up:
Alan (squadron leader) Marriette.
you want power and lots of it!
Hey... don't give FT a hard time... You gotta keep in mind... He is leaving for Reno in the morning... Dude is a rev head and likes really, really fast planes! lol
Yep mate sure does ... what does the Lazair have ? Isn't it between 10 and 16 HP 007_rofl.gif.8af89c0b42f3963e93a968664723a160.gif007_rofl.gif.58d9bf00d5ae63581bfb97e7e2434bca.gif.David
11 total maybe on a really good day early in the morning.
I had an early single seat Thruster with a 277 on it. Required a gentle touch. But it went as far if not further than a Thruster with a 503.
My Winton Swing Wing also had a Rotax 277 and did 50 kts at 5,000revs, 55 kts at 5,500 revs and 60 kts at 6,000 revs.
This aircraft is still performing well with it's present owner at Renmark, SA.
Alan Marriette.
What about a engine designed for a aircraft instead of a mower?
How about the Verner JCV360- flat twin, watercooled, redrive, very light and good power
http://www.vernermotor.com/index.asp?sec=42&gal=photo110404
The cost is about the same as a converted mower from the states. Approx $5000.
I just think it has to be a better prospect for reliability.
Displacement 360 cc / 23.06 cubic inch
Bore 63 mm / 2.47 inch
Stroke 58 mm / 2.28 in
Compression ratio 1 : 11
Maximum power 35 BHP (25,7 kW) @ 7800 RPM
Max. continuous power 26 BHP @ 6000 RPM
Torque 33 Nm @ 7000 RPM
Propeller rotation CCW, viewed from the front (tractor propeller)
Weight dry weight 26,4 kg
Spark plugs NGK CR9EK or equivalent
Spark plug gap 0.5 mm (0.02 inch)
Electric starter 18 V/370 W
Generator (Alternator) 12 V/100 W
Lubrication semi-synthetic 4 stroke motorcycle JASO MA/MB oil
Fuel motor petrol, octane number 95
Fuel pump vacual Mikuni
Carburetors 2 × Walbro WB-37-1
Reduction drive 2,76 : 1, via belt (width 42 mm, length 610 PJ)
Propeller hub ø75 - 6 x M8, ø70 - 6 x M6, ø50 - 6 x M6
Weight cooler - 0.74 kg, oil 1l ~ 0.8 kg, watter 1l ~ 1 kg, exhaust - 1.6 kg
