sseeker Posted May 5, 2011 Posted May 5, 2011 25nm from takeoff point. Can be any airfield. Landing at other fields without XC is a hazy area and someone more qualified will be able to clarify that for me. Most schools won't allow you to land at other aerodromes without XC though (just FYI) -Andrew
Guest Jake.f Posted May 5, 2011 Posted May 5, 2011 Ah ok that is good then. I wouldn't be intending on landing at other airfields just was wondering, it would have been irritating if I had the cert. but the 25nm was only from Coffs...
.Evan. Posted May 5, 2011 Posted May 5, 2011 Check out RA-Aus Ops Manual: Section 2.01-1, 4 It mentions 'not greater than 25 nautical miles from the point of departure unless you have a X-Country endorsement. It also states that Consecutive flights of 25 NM do not comply with this requirement. No mention that I can see of a 'home aerodrome' or anything. Once you have a certificate, you can go to another airfield, rent a plane and fly it in the local area...
Guest Jake.f Posted May 5, 2011 Posted May 5, 2011 Do they do training or just hire out a/c? Also I'm assuming no one knows of any RAA schools in Armidale...
Guest davidh10 Posted May 5, 2011 Posted May 5, 2011 That is quite good then, I think I'm going to have to try rather hard to get the certificate before uni so I can on the odd occasion jsut go hire an aircraft for a while, I am thinking flying will be the only thing keeping me sane while I spend 7 years doing medicine.... Naaah, You'll fly through it
Guest Jake.f Posted May 8, 2011 Posted May 8, 2011 Thanks for that, I suppose I shall see where I end up. I think there is a 95% chance I will be living in Newcastle next year so I shall check them out. I found another school who use Jabiru's and operate out of Cessnock as well...
shafs64 Posted May 10, 2011 Posted May 10, 2011 Saw one of them at the Avalon airshow 2009 looked nice. i have never flown a Jab only tecnams and GA. thanks for your insight.
facthunter Posted May 11, 2011 Posted May 11, 2011 Some retract Pioneers have a 6 cyl Jab engine. They look and fly very nicely. Nev
Tomo Posted May 11, 2011 Posted May 11, 2011 So are the Pioneer P200 a good aircraft to fly? I fly a P200 Hawk, which is almost the P300 without the retracts. The one I fly has the Constant speed prop and Rotax 100hp - goes like a rocket! They're a nice aeroplane, but have a fairly decent price tag unfortunately. 1
