Here is a step-by-step guide that you can use to teach yourself how to tie the Modified Seine Knot that is used to secure covering fabric to your aircraft.
Old Man Emu
A Practical Guide to Rib Lacing using the Modified Seine Knot Abriged.pdf
  • 1 month later...
  • 1 month later...
Hey OME
Check out the Stits manual couple of very good methods for rib stitching including one that alows you to end up with the Knot in side the the wing under the fabric all you end up wih on the surface are the cross over threads.
Regards RickH
. [ATTACH]12837.vB[/ATTACH]
Guest Maj Millard
One thing often neglected with ribstitching, is people do not run a re-inforcing tape along the top of the rib (on outside), before rib- stitching. This one step alone increases the strength considerably, by decreaseing the chance of the stitch pulling through the fabric only, and now has to pull through two thicknesses of fabric. Well worth doing for little extra weight and twice the strength !..A recommended proceedure in the industry...........Maj...024_cool.gif.7a88a3168ebd868f5549631161e2b369.gif
