pilotdave69 Posted July 6, 2010 Posted July 6, 2010 Hi all, Just saw on news that a Air van crashed at Orange after clipping top of hangar and nosedived, luckily the 43 yo pilot wasnt hurt too badly. Aircraft was on a delivery from Parkes to Orange when the accident happened. Plane nosedives into tarmac after clipping hangar - ABC News (Australian Broadcasting Corporation) Dave
pudestcon Posted July 7, 2010 Posted July 7, 2010 I'd be very interested in the circumstances that would cause an aircraft to be in a position to 'clip' the top of a hangar. Pud
pilotdave69 Posted July 8, 2010 Author Posted July 8, 2010 Bathurst man survives light plane crash - Local News - News - General - Western Advocate here is another story in the Bathurst local paper, he was a local guy, unsure of his name, but i could imagine he would be well known.
Ben Longden Posted July 8, 2010 Posted July 8, 2010 had a look at the met observations at the time...temp around 3.8c, dew point 3.7c, humidity 99% with a brisk SW breeze.. I know Orange quite well, and it has its own microclimate... an average of a five degree drop in temp as you come over the hill into town from Parkes. So the fog issue is well known. But, I always thought you had to have still air to form a fog.. Ben
Guest ozzie Posted July 8, 2010 Posted July 8, 2010 I know Orange quite well, and it has its own microclimate... an average of a five degree drop in temp as you come over the hill into town from Parkes.So the fog issue is well known. But, I always thought you had to have still air to form a fog.. Ben [inspector Luke Rankin said it was still unclear why the accident happened or if the foggy conditions were a contributing factor] The field probably looked good from overhead but visbility probably became poorer as he came in to land. similar event happened at bathurst some years back with a MU2 accident
facthunter Posted July 9, 2010 Posted July 9, 2010 "Normal" fog usually happens when calm air cools by radiation to a temperature where condensation occurs. This is when the wet and dry bulb temps co-incide. FOG may form when cool air descends from a mountain and encounters moist air lower down at lower level. Low cloud even to ground level can form when air rises due to topographical factors, ( mountain range/coastal cliffs) with wind blowing. To an observer on the ground or just above it, this will look just like fog and does not move away with the wind flow because it is being formed constantly, just like a lenticular cloud forms at a base level and sits in the one place even though it may be caused by quite strong winds. Common in New Zealand." the Land of the Long White Cloud". The problem with fog and some low cloud is that when you are looking down you can see through it. On approach because of the "slant " view through the cloud/fog not so easy. Can catch you out. Nev
Deskpilot Posted July 10, 2010 Posted July 10, 2010 OK, I've never been to Orange so I've just looked it up on Google-earth. Now, it's said something about coming from the South West so one asks, was he on a straight in approach to the grass runway? As far as I can see, that would, if misaligned, put him in line with a couple of hangers. The only other alternative would have him flying parallel to the paved strip. Which ever it was, what the hell was he thinking to attempt a landing anyway? Gethomeitus? Just glad to hear he's ok though.
