country kid Posted February 21, 2010 Posted February 21, 2010 i just got a new ute and i spend alot of time around airfeilds so my idea was is it possible to get a radio mounted in you car?? is it legal? if you can any recomendations as to were to get one from or advice on how to set one up would be great. Cheers all
GraemeK Posted February 21, 2010 Posted February 21, 2010 No problems if it's only receiving (eg scanner). To transmit, you need a Radio Operator Certificate (RAAus) or Flight Radiotelephone Operator Licence (GA). These come with your licence. Use of the radio itself is governed by a Class Licence issued by ACMA which allows use from a ground-based (mobile) station under certain circumstances.
country kid Posted February 21, 2010 Author Posted February 21, 2010 ok well im getting my RA-Aus licenes soon any how but abliviosly you still couldnt transmit from the ground unless you have the license to do so? any ideas were i could find a car mounted scanner?
Guest 172M Posted February 21, 2010 Posted February 21, 2010 As previously stated, you cannot transmit(unless licensed in an aircraft, or hold the appropriate ground operators qualifications) from the ground. Scanners.. Dick Smith, Jaycar or ebay for a cheap one . Most scanners cover AM Airband as well as the rest of the "chook sheds" Cheers
skeptic36 Posted February 21, 2010 Posted February 21, 2010 Hi Country Kid, I think the scanner is definitely the way to go. When you do your radio endorsement you will see that aircraft radios are only for use to communicate necessary information such as your position, clearances from air traffic control etc. When you start flying you will also realize how annoying it can be when the chit chat gets to be too much. So it is hard to see that there will be to much opportunity for you to transmit from your car. Regards Bill
lbarnes Posted February 21, 2010 Posted February 21, 2010 I have one of these that lives in the centre console. Communications :: Scanners :: Maycom AR-108 Airband Scanner - Aviation Pilot Supplies Shop | Flight Gear | Aircraft Instruments I use ersa to program in the relevant freqs for the areas that i will be driving, handy at airshows too.
country kid Posted February 22, 2010 Author Posted February 22, 2010 can you get a scanner that mounts into your car tho?? iv got a uhf but i want a mounted scanner?? any ideas were to find one??
Bubbleboy Posted February 22, 2010 Posted February 22, 2010 Something like this :: Uniden Australia ::
country kid Posted February 22, 2010 Author Posted February 22, 2010 um yeh same concept exepc you can mount it into a car. thats a desk unit. but its a good lead
country kid Posted February 22, 2010 Author Posted February 22, 2010 you guys know more about radios than me dose any one know if this one will do the job cheers all Uniden BCT15X Mobile Base Scanner
Thalass Posted February 23, 2010 Posted February 23, 2010 VHF airband is not CB - you can't just chat away. But I think if you have a pilot's radio certificate then you can communicate from your car to aircraft - if you have a legitimate reason. Listening in is a good idea to learn the pace and phraseology pilot's use, if you're training. I suppose if you were ground crew in a chase car, or coordinating a temporary landing strip, that'd count as a legit excuse to use airband on the ground (legalities of being an ATC without airservices approval aside). We use airband at work to talk to incoming aircraft for ETA and any defects to report, etc. But like I said: Legit use. As far as chatting goes: Is there any reason you couldn't use UHF CB? I imagine flying in convoy would mean a fair bit of chatter, and IIRC the regs say that even selcting an unused airband frequency for chatting is frowned upon.
Guest Kevin the Penniless Posted February 23, 2010 Posted February 23, 2010 That scanner would pick up the airbands - 118Mhz to 136Mhz. It's a very hoopy system. I've not come across a scanner that wouldn't (being an ex radio tech I saw a lot of that stuff). What's this about needing a special licence to operate a handheld on the ground?
country kid Posted February 23, 2010 Author Posted February 23, 2010 yeh you do need a license to operate a airband radio from the ground other wise it would be open slather and the talk would be so much so that getting an ETA or clearance would be a hassal the idea of getting a scanner is simply because i spend time on un controled airfeilds and around airfeilds in general for one reason or another i also live near one so its just interesting to know what coming and goinging, and were everything is. purly for interest oh and they pick up police frequencies but thats not important to me.
jetjr Posted February 23, 2010 Posted February 23, 2010 You need a radio users licensence to use airband ANYWHERE The Airband radio needs to be approved for ground transmission too. No idea why Latest Vertex handhelds arent but old model was certified
Thalass Posted February 23, 2010 Posted February 23, 2010 You need a license to transmit on airband from the ground for exactly the reason countryboy said. We all know how 'cultured' CB is. How could anyone get anything done in the air if the frequency was choked with those sorts of peoples' chatter? hahaha Nothing illegal about listening, though.
country kid Posted February 24, 2010 Author Posted February 24, 2010 well thats fair dinkum its probly a good idea but hopefuly it will never get to that point in australia, i mean they band laser pointers because of arrogant youth so if every one could use an airband radio? and yes even getting in at jandokot can be hard during the "peak hour"? i dont think i will try getting an airband radio in my car unless in the near future we have an airstrip built on our property. which probly wont happen, has any one else thought of installing something like this in their car?
