Guest mike_perth Posted January 20, 2010 Posted January 20, 2010 Well I thought Id just drop in and let you all know that I yesterday passed my PPL flight test!! It was a enjoyable journey and one I will never forget the feeling yesterday after completing the test was indescribable - nothing compairs to it! I cant imagine what it must be like to complete your CPL! So look out skys above cause here I come!! Mike
mAgNeToDrOp Posted January 20, 2010 Posted January 20, 2010 Congrats Mike well done! Wow must have been interesting yesterday in 40 degrees plus :) Hope to see you up there in the blue stuff sometime
perthjay85 Posted January 20, 2010 Posted January 20, 2010 Hey congrats mike. glad to see it all went to plan, and i notice min has now started recommending the bob tait books a bit more.
skybum Posted January 20, 2010 Posted January 20, 2010 Yes, congrats, Welcome to the real world...if only I could afford the upkeep:laugh: I would be aviating every day.
Guest mike_perth Posted January 20, 2010 Posted January 20, 2010 It was very interesting when we landed in Northam it was 44degC on finals at 700agl!! Would have been a good day in a glider as the thermals were pretty strong at some points in the flight. Did a couple of stalls and a few steep turns plus some instrument flight in the training area on the way back - the total flight time was 2.6 hours so you can imagine I was pretty hot and sticky after all that!! Cheers Guys Mike
Relfy Posted January 20, 2010 Posted January 20, 2010 Awesome work Mike. You'll have to run us through the nervous moments of the test! :thumb_up:
perthjay85 Posted January 20, 2010 Posted January 20, 2010 ah its not all that bad i clocked up 2.7 hours on sunday lol. its only heat after all, just keep your fluids up and you will be fine. invest in a camelpack. it takes a bit to get it feeling comfortable but you have up to 2 litres for your trip that is kept quite cool
pudestcon Posted January 20, 2010 Posted January 20, 2010 It was very interesting when we landed in Northam it was 44degC on finals at 700agl!!Would have been a good day in a glider as the thermals were pretty strong at some points in the flight. Did a couple of stalls and a few steep turns plus some instrument flight in the training area on the way back - the total flight time was 2.6 hours so you can imagine I was pretty hot and sticky after all that!! Cheers Guys Mike I assume you would have used 14 Mike; how were the thermals on late final between the road and the threshold? They usually play havoc with the Thruster, then your attention can be upset by the 'white cockies' flying across the strip as you touch down - its all good practise. Pud
Tomo Posted January 20, 2010 Posted January 20, 2010 Good on ya Mike, well done! :thumb_up: Thanks for sharing with us... :big_grin::thumb_up:
pudestcon Posted January 20, 2010 Posted January 20, 2010 Oh yeh Mike, forgot to add my congratulations as well:blush: Good onya mate:thumb_up: Pud
Guest mike_perth Posted January 20, 2010 Posted January 20, 2010 Cheers guys! Due to popular demand (well refly asked) Ill give you a bit of an account of the flight and some of the highs.......and lows! We departed YPJT (Jandakot) via VFR reporting point Armadale and then flew up controlled airspace (V66) to another reporting point The Lakes (TLKS) this part of the flight is apparently were most students get it wrong and I’ve been told if you get this part wrong then the flight test usually doesn’t go your way not because of the departure but because if you get flustered here then things usually compound - thankfully for me I’m reasonably comfortable with the departure and I feel did a reasonable job of it, even though I did it from a runway I have never done it from before (RWY24 usually I fly in the morning with an easterly and depart RWY06) But after TLKS we changed course and headed for Northam (YNTM) for a few touch and goes - thankfully I heard another aircraft in the circuit meaning I knew the runway in use and could let down to cct height without over flying as all circuits here are to the East and I was approaching from the west. It was runway 32 (So I didn’t experience the thermals on 14!) but none the less it was bumpy and hot I made one normal touch and go circuit followed by a flapless touch and go - been a while since my last flapless but nothing too difficult. Well up to now everything sounds normal and it was I climbed out to 2000ft made a turn over flew the field to orientate myself and tracked for Narrogin and this is were things got a little confusing York was supposed to be on my left according to my track but after 3 mins it was on my right - I decided to continue on course until due east of York and make my track correction there as it would give me a good reference point to make measurements on the map to calculate my track error and apply the trusty 1 in 60 rule to correct it! Well I did exactly that and got back on track - I can only assume the wind was greater than forecast and we got pushed of track as my calcs were right and my heading was held correct. Once id spent all that time getting back on track the old practiced forced landing was upon me - I had been expecting it much later in the flight but its here now, and at a good point as it really was a surprise! All went good the field I chose was ok and my approach was one of my best yet! Once at 500 ft AGL I was asked to fly a precautionary search of the field which in hindsight probably wasn’t the best as it had a pretty steep down slope but still ok. It was then time for a climb back to track only to be told of a diversion to Mt Cooke - and well Ill admit it I didn’t exactly find it first go! I drew my track estimated a heading and flew it I even took into account that the wind was stronger than forecast and added an estimated 8 deg for the wind but we ended up flying too far south but I found myself established my position over Westdale (I told you a long way south) and continued to track for Mt Cooke (I could see it and could have flown straight for it but wanted to show off my Nav skills!!!) After Mt Cooke it was into the training area for some upper air work but not without some time on instruments thrown in for good measure! From here it was all pretty smooth sailing - stalls, steep turns, turns under the hood, gliding steep turns, turning stalls, followed by a normal return to YPJT via Six South with a short field landing thrown in for good measure! Sorry for the long post but thought some students out there might like to know what’s involved in the PPL flight test and that things can go wrong and as long as you fix them and show you can find yourself even when you’re "lost" the PPL flight test can actually be fun....even in 40 odd degree heat!!
Riley Posted January 20, 2010 Posted January 20, 2010 "You're a better man than I am Gungha Din!" Well done Mike.
pudestcon Posted January 20, 2010 Posted January 20, 2010 Good onya Mike, Great account of your flight and something to tell others over the years. Pud
dunlopdangler Posted January 20, 2010 Posted January 20, 2010 Congrats Mike, now your next mission will have to be the Nullabor....still worthwhile stopping at forrest (even overnight there is fun) Coober Pedy, Lake Eyre, Birdsville wherever takes your fancy and visit us over here...
slartibartfast Posted January 20, 2010 Posted January 20, 2010 Thanks for the overfly Mike - and congrats.
