Guest Pioneer200 Posted January 16, 2010 Posted January 16, 2010 I have been viewing the Jabiru site and read that they advertise the J 160 cruise speed of 100 knots @ 3050 rpm. They also say fuel burn of between 13 - 16 litre an hour. I fly a J160 here in NZ and our plane will do more than 100 knots at 3050 rpm, probably closer to 110 knots. But @ that rpm I believe it burns way more than 16 litres an hour. I work on 20 litre hour for cross countries @ 2900 rpm Is cruising @ 3050 rpm to hard on the engine?? Cheers:big_grin::big_grin:
sseeker Posted January 16, 2010 Posted January 16, 2010 We cruise at 2800rpm on our prop and we can get about 100kts. If you have a read through the J160 pilot operating handbook the aircraft has a max cruise of 112kts. If we cruised at 3000rpm we'd be getting around 112kts or above. There are about 4 different props for the 2200 engine 2 of which are approved for the J160C I think. As for fuel planning we go by 14/L an hour at 2800rpm. And I'm not sure where it says cruise at 3050rpm because I'm pretty sure that's what the engines maximum revs are.
Vev Posted January 16, 2010 Posted January 16, 2010 If you take a look at the "JabChat News Letter" (July 2009) on the Jab site they have listed fuel burn per RPM for the recommended carby jetting ... the attached is a cut and paste from Jabchat. RPM Litres/hour 2600 13.4 2700 14.1 2800 16.5 2900 17.4 3000 24.3 Full Power (3175) 28.5 In terms of max RPM, I beleive this to be 3300 RPM for the 2200/4 engine. The guys at Jab always tell you not to baby the engine and drive it hard, therefore I really wouldn't think 3050 rpm as being too hard on the engine. Cheers Jack
sseeker Posted January 16, 2010 Posted January 16, 2010 Veverjg, Correct me if I'm wrong, one of the props at our school was chipped. It was immediately replaced with another approved prop and I believe this was called a 'cruising prop'? And our engine usually sits at 3000-3300rpm (as said above) on takeoff but when this prop was put on we were getting 2800-2900rpm on takeoff full power, so really your maximum capable engine revs are down to the loading on the prop?
Vev Posted January 16, 2010 Posted January 16, 2010 Yes you are right, but your take off and climb rpm will always be lower than max rpm in S&L flight.... in S&L flt you will see the engine speed increase if you held full power. I have a varible pitch prop on my 160 and pull 2900 in static mode, 3000.3050 rpm in climb and 3300 in S&L flight at full power. I tend to cruise around 3000/3100 @ 100/105 knts. Cheers Jack
