Admin Posted January 14, 2010 Posted January 14, 2010 The Civil Aviation Safety Authority has published the following Airworthiness Directitves between 1 January and 14 January 2009. These, and other Airworthiness Directives can be viewed at: Civil Aviation Safety Authority - Airworthiness Directives Rotorcraft Eurocopter AS 332 (Super Puma) Series Helicopters AD/S-PUMA/60 Amdt 1 - Fuselage Inclined Gearbox Fairing Gutter - CANCELLED AD/S-PUMA/81 - Fuselage - Intermediate Gearbox Fairing Gutter - CANCELLED AD/S-PUMA/82 Amdt 1 - Hydraulic Hoist Cable - CANCELLED Eurocopter AS 350 (Ecureuil) Series Helicopters 2009-0277 - Portable Halon 1211 Fire Extinguishers 2010-0006 - Tail Rotor Pitch-Change Links Eurocopter AS 355 (Twin Ecureuil) Series Helicopters 2009-0277 - Portable Halon 1211 Fire Extinguishers 2010-0006 - Tail Rotor Pitch-Change Links Eurocopter EC 120 Series Helicopters 2009-0277 - Portable Halon 1211 Fire Extinguishers Eurocopter EC 225 Series Helicopters AD/EC 225/9 Amdt 1 - Fuselage - Intermediate Gearbox Fairing Gutter - CANCELLED Below 5700 kgs Aerospatiale (Socata) TBM 700 Series Aeroplanes AD/TBM 700/48 Amdt 1 - Main Landing Gear Wheel Axle - CANCELLED 2010-0005 - Main Landing Gear Wheel Axle Beechcraft 18 Series Aeroplanes AD/BEECH 18/17 Amdt 5 - Aircraft Modification, Inspection and Retirement GAF N22 and N24 Series Aeroplanes AD/GAF-N22/52 Amdt 1 - Stub Wing Upper Front Spar Cap Grob G115 Series Aeroplanes 2009-0279 - Canopy Jettison Piper PA-46 (Malibu) Series Aeroplanes AD/PA-46/19 Amdt 1 - Wing and Fuselage Structural Fatigue Limitations - CANCELLED Above 5700 kgs Airbus Industrie A319, A320 and A321 Series Aeroplanes AD/A320/8 Amdt 2 - Angle of Attack Sensors Airbus Industrie A330 Series Aeroplanes 2009-0237-E (Correction) - Oxygen - Oxygen Containers - Inspection Avions de Transport Regional ATR 42 Series Aeroplanes AD/ATR 42/19 Amdt 2 - Fuel Tank Safety Fuel Airworthiness Limitations - CANCELLED 2009-0276 - Portable Halon 1211 Fire Extinguishers Boeing 717 Series Aeroplanes AD/B717/15 - Flight Management System - CANCELLED Boeing 727 Series Aeroplanes AD/B727/209 - Fuel System Airworthiness Limitations - CANCELLED Boeing 737 Series Aeroplanes AD/B737/329 - Airworthiness Limitations and Inspections - Fuel Systems - CANCELLED AD/B737/331 - Airworthiness Limitations and Inspections - Fuel Systems - CANCELLED 2009-20-11 (Correction) - Fuel System Limitations - DTSD 2009-26-04 - MLG Forward Trunnion Pins 2009-26-03 - Standby Static Inverter 2008-10-09R1 - Airworthiness Limitations and Inspections - Fuel Systems 2010-01-08 - Wing Centre Section Lower Stringers 2008-10-10R1 - Airworthiness Limitations and Inspections - Fuel Systems 2010-01-09 - Fuselage Skin at Stringers S1 and S2 right, between STA 827 and STA 847 Boeing 747 Series Aeroplanes AD/B747/51 - Fuselage Frames - Aft Cargo Bay - CANCELLED AD/B747/52 - Lower Fuselage Frames - CANCELLED AD/B747/155 Amdt 2 - Thrust Reverser Pneumatic Drive AD/B747/157 Amdt 2 - P&W JT9D Aft Engine Mount Tangential Link 2009-26-03 - Standby Static Inverter 2008-10-06R1 - Airworthiness Limitations and Inspections - Fuel Systems Boeing 767 Series Aeroplanes AD/B767/242 - Airworthiness Limitations and Inspections - Fuel Systems - CANCELLED 2009-26-03 - Standby Static Inverter Boeing 777 Series Aeroplanes 2009-26-03 - Standby Static Inverter 2009-24-08 - Fuselage Scribe Line Damage Boeing 767 Series Aeroplanes 2008-11-01R1 - Airworthiness Limitations and Inspections - Fuel Systems Bombardier (Canadair) CL-600 (Challenger) Series Aeroplanes CF-2009-49 - Wing Leading Edge Thermal Switches and Wing Anti-Ice Duct Piccolo Tubes - Airworthiness Limitation Tasks CF-2009-50 - Air-Driven Generator (ADG) - Non-Conforming Balance Washer Screws British Aerospace BAe 146 Series Aeroplanes AD/BAe 146/137 Amdt 1 - Nose Landing Gear - CANCELLED 2010-0001-E - Nose Landing Gear Cessna 560 (Citation V) Series Aeroplanes AD/CESSNA 560/9 - Minimum Airspeed Placards - CANCELLED AD/CESSNA 560/11 - Aileron Fairlead Interference Cessna 680 (Citation Sovereign) Series Aeroplanes AD/CESSNA 680/2 - Honeywell Primus Epic System Cessna 750 (Citation X) Series Aeroplanes AD/CESSNA 750/4 - Elevator Inboard - Hinge Brackets - Inspection AD/CESSNA 750/5 - Reset Circuit Breakers - Replacement Fokker F100 (F28 Mk 100) Series Aeroplanes 2009-0216R1 - Horizontal Stabilizer Control Unit Dog-Link Attachment SAAB SF340 Series Aeroplanes AD/SF340/54 Amdt 2 - Ceiling and Lavatory Lights - CANCELLED AD/SF340/83 - Replacement of Hydraulic Hoses - CANCELLED AD/SF340/109 - Ceiling and Lavatory Fluorescent Lights AD/SF340/110 - Passenger Compartment Fluorescent Lights Piston Engines Lycoming Piston Engines AD/LYC/119 - ECi Cylinder Assemblies - CANCELLED 2009-26-12 - ECi Cylinder Assemblies Turbine Engines AlliedSignal (Garrett/AiResearch) Turbine Engines - TFE731 Series AD/TFE 731/24 Amdt 1 - First and Second Stage Low Pressure Turbine Discs AD/TFE 731/26 Amdt 1 - Low Pressure Turbine First and Second Stage Disc Suspect Material Properties Pratt and Whitney Turbine Engines - PW4000 Series AD/PW4000/6 - Inspection of Critical Life-limited Rotating Engine Components - CANCELLED AD/PW4000/10 - Engine Stability Improvements - CANCELLED Turbomeca Turbine Engines - Astazou Series 2010-0004 - Engine Rotating Assembly - Third Stage Turbine Wheel - Inspection / Removal
