Ed Herring Posted December 16, 2009 Posted December 16, 2009 Hi Gang With a touch and go you should return flaps to take off position ( whatever is required for a normal take off ) it is very important to not get confused regarding operation of flaps with a touch and go and a go around ( missed approach ) Best Regards Ed
Tomo Posted December 16, 2009 Author Posted December 16, 2009 Hi GangWith a touch and go you should return flaps to take off position ( whatever is required for a normal take off ) it is very important to not get confused regarding operation of flaps with a touch and go and a go around ( missed approach ) Thanks for that Ed... I asked the instructor, (Well He actually told me before I remembered to ask!). In our situation you add full power and 'then' retract flap to take off position. Reason being is the strip isn't that long, and it really leaves you without much length left by the time you retract, then add full power... The only thing you have to watch is that you either keep it on the ground until flap is in the correct position, or make sure you have enough speed on so as not to sink back onto the runway, works quite well... The above is for a touch-n-go...
