Outback Posted October 8, 2009 Posted October 8, 2009 Having just test flown my J430, I'm finding the throttle control (on the panel) not too smooth when changing power settings. I've adjusted the tension and its still pretty jerky. Maybe I'm just used to the vernier type in a previous GA aircraft. Just wondering if anyone has installed a vernier throttle on the Jabiru. I see they are available from Spruce. Garry
Guest Rod Posted October 9, 2009 Posted October 9, 2009 G,Day Garry, Just bought a J250 with a Vernier and it is "smooth as" and great after the normal push pulls on my Zodiac. This one is fitted on the outside left of the dash panel so leaves dash as a easy out unit. The door arm rest is in the perfect position for your arm to rest and operate the throttle. Cheers Rod.
