Guest S.Greaves Posted September 16, 2009 Posted September 16, 2009 Has anyone successfully used a Zulu headset with a Vertex 220? I have been trying using a PTT switch without any success. Would appreciate any help. Stephen Greaves
jetjr Posted September 17, 2009 Posted September 17, 2009 I recently had problems with a vertex and D Clarks (with ANR kit) - may not be relevant, but one of the headset plugs was going into adapter too far, had to space with a washer to get good contact. Also ANR picks up bad feedback from handheld through headset leads, need 2 x ferrites on the headset to solve JR
gas man Posted September 19, 2009 Posted September 19, 2009 It took two washers for me to get adequate spacing and I bonded them to the socket with a dash of alraldite. I find vertex plus lightspeed to be better than my panel radio. The unit works 100% better when connected to the aircraft antenna although I think it might damage the radios if they were both connected to the same antenna simultaneously.
Guest S.Greaves Posted September 20, 2009 Posted September 20, 2009 Thanks for your help everyone. I now know it can be done. Cheers
